ZX750.1 up in flames.
Did you replace the driver transistors for the power supply FETs? They are Q05 and Q11 near the 494. Check them for open junctions as well as for leakage and being shorted.
There is at least 1 screw near the TL494 that has a silver solder pad around it. The screw with its lock-washer must be installed and tight. If that's in place and the amp won't power up, try twisting/pushing/pulling on the power transformer. Does that, at any point, allow the amp to power up?
If not, I'd recommend removing the main rectifiers to see if that will allow it to power up. After removing them, make sure that there are no solder bridges between the pads on the top or bottom of the board.
