I don't see a problem with this. You probably don't even need the resistor, since screen current is never zero. Zener noise probably isn't a problem either, since the screen grid is so insensitive.Is there any drawback in adding a zener diode in series with the UL connection, adding a resistor to ground in order to always ensure at least 2 mA through it
AC attenuation of g2 voltage due to UL ratio (referred to peak negative anode voltage) + DC shift due to zener voltage > cathode voltage.
The zener will restrict the g2 negative peak (must not go below the instantenous cathode voltage), hence it will restrict the available output power.
This may have been covered before, but my search was useless.
Last night I was discussing Ultralinear output stages with a friend of mine and he mentioned using zener diodes to drop the voltage on the screen. This could be important if driving a vintage 6550 or perhaps a sweep tube. This reminded me of an old article in Sound Practices which I looked up:
from "The Classic Williamson 1993 Style" by Bill Kleronomos (Sound Practices #4)
"An unusual method of applying active screen voltages to the tubes is used. Instead of the usual dropping resistors, I used a set of 5 Watt Zener...
- kstagger
- Forum: Tubes / Valves
it seems that no progress since 2021 on this strange way
Walter
Hi, as I wrote many times, here I'm using low UL percentages and fixed bias, plus flattish loadlines, so (almost) no power reduction.AC attenuation of g2 voltage due to UL ratio (referred to peak negative anode voltage) + DC shift due to zener voltage > cathode voltage.
I'am guessing its a gu50. Another option is a mosfet to the screen. That way you can combine 0V, HT and plate in any ratio you wish without a UL tap.
- Tubes / Valves
- Zener in series between UL and screens: any drawback?
