Zener + Emitter Follower voltage regulator
Alcaid said:
Would you prefer metall oxide or wirewound resistors as R1,R11 and R5,R15?
You can choose either type but I would also have a resistor at first. R-C-R-C by that you will have less harmonics. Resistors value of 1-4.7 ohms is OK.
You can also choose plain metal film as long as you have control over the power and inrush currents. 1-4 metal film is sufficient I think.
How do I calculate the power dissipated in these resistors?
I'm going to use a toroid (50VA) without any soft start circuitry, so a 1/4W resistor wouldn't survive I guess.
Elso Kwak said:
Hello Alcaid, How about this one?
You can use the LM431 or a Sziklai connection in place of the Darlington. A constant current source for the reference improves the sound. If you use an inductor in place of R1 (in your scheme)you will get better ripple rejection.😎
Well, at first I was aiming for simplicity. I've seen your circuit in another thread, and even though I'm getting further and further away from the simple circuit at the beginning, yours seem like too much for me. 🙂
Do you mean this graph?
Don't understand how to find the right value.
It's a BZX 79 15V zener.
That is correct. Look in the table differential resistance for your zener, I think it was a 9.1V zener?
You will see that at 5mA reverse current the dynamic impedance is max 15 ohms. That 5mA also seems the current where the zener voltage variation is closely centered around 9.1V, so that seems a good value.
I didn't realise they stopped publishing the reverse characteristics. Probably too many cook-book technicians not understanding those curves anyway. Oh well, such is the price of progress...
Jan Didden
