Zen vs ZV9
Thanks Nelson and Maqura for your answer.I still have a few questions.First question how critical is the value of C8?I only find 22pF original it is 20pF.I also couldn't find for R1,2 and 3 the 2 ohm/3Watt mox,1,8 ohm and 2,2 ohm isn't a problem.
Adjust R3
I couldn't find the post, but I did find the information in the ZV9 article on www.passdiy.com - page 9 of 10 in the following:
http://www.passdiy.com/pdf/ZV9.pdf
As yet another alternative if you don’t want to test the devices, I recommend that you simply select R3 so that the Vds of the JFET in the amplifier is 2.5 volts with the output DC figure of 23 volts. More often than not, this is close to the sweet spot.
