From what I understand just matching the impedance is only the start. It will have a different sensitivity (fairly easy fix) but the TS parameters will be different so box size and tuning will be different.
Example - using the mh-audio bass reflex calculator as a quick estimate with a similar driver -
Satori MW16p-4 = 13.3l box, f3 of 50hz with 5cm diam x 22cm long port and spl 88dB (flat response)
Satori MW16p-8 = 24.7l box, f3 of 39hz with 5cm diam x 15cm long port and spl 87.5dB (flat response)
T/S parameters look way different to the 8ohm version. You're probably going to get a peaking midbass and a lack of lower bass in the enclosure designed for the 8ohm version. It'll probably want a sealed enclosure that is 20-50% larger. Vented enclosure will need a total redesign.
Aside from that, make all inductors and resistors in the woofer section half the value, make caps in the woofer section twice the value.
Adjust R0 to between 1-3ohm to set tweeter level to match.
- Zaphaudio SR71 with 4 ohm ER18RNX
