Zapco Studio 500 repair
I recently acquired a Studio 500 amplifier.
I've had some difficulty searching for a service manual for this unit.
I did reach out to Zapco earlier today to see if they have one available they are willing to share.
I've not tampered with anything on the board so far, just removed a couple heat sink clamps to test the voltage regulators.
I've powered the amp on
No protect light, very little DC offset (.02)
No sound out.
If I crank the gain knob the clip indicators will slowly flicker as I adjust the gain.
There is no sound out, at all.
I've got +15 on pin 1 and 3 of tip31 and -15 on its counter part
I've got lots of photos.
There are not any muting relays
Here are a couple photos.
Hi Perry,
Which diagram would you like to see? It's broken down in to sections.
I have separate attachments for input, layout, output, and supply
The lay out does not have the schematic, but the others do.
Can I attach PDF files here?
Set your meter to AC voltage, lowest range if not auto-ranging. Drive a signal into the amp and turn the gain until the clip LEDs just light up. With the black probe on a non-bridging speaker terminal. Touch the red probe to the various large blue 0.2 ohm resistors. Do you read more than a fraction of a volt on any of them?
