- 2.6
- 2.6
- 034mv
- 172.6mv
- 2.07
- 3.83
- 2.07
- 4.936
- 1.73
- 025.1mv
- 2.87
- 013.4mv
- 17.32
- 2.96
- 17.28
- 5.2
Sorry about that.
Those are OK.
What is the DC voltage on all legs of q50 and 51? Only post for one if they're the same.
q50
- 059.6
- 013.3
- 013.3
- -015.8
- 013.7
- 013.7
If you short between pins 7 and 8 of U8, does the amp produce audio?
If you have speakers and a signal source connected, have the volume low.
No it is not in protect mode. I'll have to redo the test as I only had one speaker connected
The audio was clean though
I tested again with both channels driven. Clean and no protect light. This was jumping pins 7/8 on u8
Yes, but it's likely easier to make the connection to the ground on the ground terminal of the amp.
U7
U3
- 11.5
- 11.5
- 013mv
- 014mv
- 11.24
- 11.6
- 015mv
- 11.26
- 016.2mv
- 11.65
- 11.39
- 015.8
- 016mv
- 11.68
U3
- 11.63
- 9.75
- 016mv
- 016.7mv
- 016.4mv
- 016.6mv
- 016.6mv
- 11.3
- 11.63
- 016.6mv
- 11.65
- 016.6
- 016.6
- 11.68
- General Interest
- Car Audio
- Zapco Studio 500 repair
