Ready to attach the 74 film:
But I need four hands for that, so I have to keep you in suspense for a while.
Note that the paper backing in the alu/paper foil isn´t necessary anymore; it should be possible to use spray mount aluminium foil directly to the A3 paper.
There´s a lot of experiments to do...
Seems that you got a fine helper for the cutting
Looking good.
I have send you some 7/15 my alu/mylar.
Pleace try to cut it.
Bernt.
Looking good.
Bernt.
Here a drawing:
Try carefull,dont ruin the fine machine
Height is 160mm length app. 255mm.
Bernt
![URL]](/community/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fimg833.imageshack.us%2Fi%2Fhco2.jpg%2F%5D%5BIMGDEAD%5Dhttp%3A%2F%2Fimg833.imageshack.us%2Fimg833%2F2702%2Fhco2.jpg%5B%2FIMGDEAD%5D%5B%2FURL%5D&hash=af21bc0d1ee64847dbe6e0f68cf1dd3a)
Bernt
So the rim is 3 mm but the actual membrane is 160 times 255?
Alu is 5 mm and the space 3 mm?
Yes, it is very versatile.
Apart from tracing and cut from jpeg, dxf, gds, svg, png, bmp, gif and tiff input,
you can also print the picture or any original Silhouette Studio material and then cut it out. The print out is supplied with registration marks that the cutter detects and then starts cutting.
There are lots of videos on Youtube showing this; the cutter is quite popular amongts "scrappers".
Seems that I got the blade inserted wrong.
The jaggedness that you see in post #302 shouldn´t be there.
What is the machine you are using and what did it cost, what size does it go up to? Thanks Jamesbos.Sprayed some remount on a A3 paper and attached the alu/paper on it and loaded it into the machine:
Oops, forgot to mention that in this thread.
It is the Silhouette Cameo.
Its primary customers are the scrap bookers, so if have you any female (what, me prejudice?) friends, sisters, mothers or daughters around you it should be easy to sell in the idea of getting one.
For us diyaudiees it can be used for making membranes for AMTs but also ordinary ribbons as its capacity is 300x2500 mm (12"x10').
By using self adhesive vinyl one can use it to make logos for your diy speaker or front panel for your diy amplifier.
Its around $300 in the US, £260 in the UK and €300 in other European countries.
However, instead of printing it uses a small blade to cut paper, cardstock, vinyl, fabric and more up to 12" wide and 10 feet long.
Look, only two hands!
Made a fixture in order to apply the 74 film easier:
Some guide pins on the frame.
Apply the film according to the markings:
Fixate the newly cut membrane on the bottom:
Put the frame on top and just gently press down the film from the middle:
The membrane came off really easy, in fact, I think I could have left out the cutting of the paper.
Slight mistake though. At the pen, the aluminium is only 4 mm when it should have been 5 mm.
Well, that´s easy fixed and then cut a corrected membrane.
Or, replace the blade with sketch pens or even a ordinary pens
Smart!
And easy too,having the right tools.
The cutter is made in a cheaper version too:
Pre Order Brand New Silhouette Portrait Digital Electronic Craft Cutter | eBay
Bernt
Bernt
You mean the Silhoette Portrait??
It is 8" wide instead of 12" but I guess it´ll do for AMT manufacturing.
- Planars & Exotics
- Yet another DIY AMT
