Rough draft of the firmware. It compiles, but is totally untested! 😱
Maybe you covered it, but: would this work two ways, either switching a single source to two 'receivers' like headphones, as well as switching one of two sources to a single headphone/receiver?
Jan
Jan
also, it would be easy to make a variant of this which switches RCA jacks instead of headphone jacks (there is even an unused spot on the ground relay for the second ground).
In my head I attached RCA jacks to the enclosure and wired them to the headphone pads on the pcb 😉
Board mistakes:
I'll spin another rev of the board design to address these (but again, they are non-critical errors).
- I accidentally used the small signal trace width after the micro switches, which carry the full current of the entire circuit 😕. Practically speaking, this isn't actually a problem, as the circuit draws less than 100mA, but it is a mistake nonetheless.
- Somehow the drills were not performed for the mounting corner M3 holes and the alignment pins on the headphone jacks. I was able to work around this by using a sheet metal punch for the M3 holes, and by clipping off the plastic headphone jack alignment pins.
- As mentioned previously, the diodes immediately after the microswitches aren't needed.
Got the board assembled, but it turns out I don't have any Arduino Nano's on hand, argh! 😱 Turns out what I had on hand are Arduino "Pro Micros", which are shorter with a different pinout. Amazon Prime can have them to me tomorrow 😀
I really like the microswitches, first time I've used those as a user interface 😀
Squeezing the soldering iron inbetween the relays was a bit dicey. Just barely enough room. This caught me by surprise -- not used to dealing with surface mount parts! 😱
Ok, Arduino Nano's arrived, and I got the board flashed and am testing it out.
First problem: apparently I misunderstood how the input protection diodes work in an Arduino? I used 100k current limiting resistors, which still allows the full 9V to appear on the input pins, but limits the current to something which the clamping diodes can safely handle.
Well, somehow, voltage is appearing on all three input pins. 9V on the one which I'm actually pressing the switch for, and then about 5.3V on the other two. So somehow the clamping diodes are allowing voltage onto the other input pins?
The work-around is to switch from a series current limiting diode to a proper voltage divider for each input pin. Nothing a bodge can't fix.
but other than that, IT WORKS! THIS IS SO COOL!!!
I plugged in two sources and played different songs just to ensure things were working as expected.
One thing I was pleased with was that even this simple way of obscuring the "reroll" (using dummy relays, and switching the relays two times) is enough to totally mask what is happening. I can't tell the difference between an "A" reroll and a "B" reroll, with or without headphones in, so this should work well for blind tests.
Also, I knew on paper that these relays were fast (4ms), but didn't appreciate just how fast it feels subjectively.
I'll get a v2 board spun up with the needed fixes, then upload all of this to github.
Here's v2 of the board, with the fixes.
Github (with BOM and tayda links): GitHub - pepaslabs/abx-tayda: A relay board for performing blind A/B testing of two audio sources.
Updated firmware: abx-tayda/abx.ino at main * pepaslabs/abx-tayda * GitHub
This looks great 😀!
I really like your random number generation approach. You might want to consider another entropy seed though - the built in random generator is only pseudo-random.
Thanks!
I briefly looked into some advanced entropy tricks for Arduino (using various circuit noise sources), but after toying with this a bit, I think the built-in pseudo random generator is fine.
The USB port of arduino could be useful for some PC control/processing. Have you considered moving the arduino to the PCB edge so that a USB cable could be directly inserted into the port, through some enclosure wall?
Ah I just realized I had totally forgotten about the pin A6 / A7 problem, which means the output relays aren't actually switching, haha 🙂
I'll post another board update which uses the RX / TX pins instead.
That's an interesting idea, but an idea for someone else's design 🙂
Here is v3:
- Use RX0, TX1 pins instead of A6, A7
- Add test points to the inputs to make volume matching convenient.
Wow, so, not only are there no p-channel TO-92 mosfets available from tayda, even via ebay the BS250 is quite expensive ($13.78 for 50 BS250, compared to $1.40 for 50 2N7000, literally 10x as expensive).
At the cost of adding 6 additional resistors, I could convert this board to use 2N3906 PNP BJT's ($0.99 for 50, if we are sticking to ebay as a pricing metric).
- Design & Build
- Equipment & Tools
- Yet another ABX box!
