Yamaha B-2 VFET bridged ? Possible ?
Hi everybody,
I was wondering if there is a way to bridge a stereo unit to use as a mono unit ( i own 4 units)
Did anybody tried it ? Is that a huge motification (if possible at all).
Those are the famous VFET unit
Thanks !
Phil
I can upload the schematics if needed....
In theory, yes - but you would be restricted to 8 ohm and higher loads, and you need either a preamp with proper XLR output, or an external bidging adaptor. Both channels MUST operate at exactly the same level setting.
Still, I would not risk it. Double the power, and you only get 6dB louder sound, with less dampling factor and more risk.
