wagnju you are a saint, I hope that we can get enough non-big cap users to get you a board meant for your caps
XO PCB GB Status:
Name / Qnty (pair) / Country
Wagnju / 1 pair / Germany
Statler / 1 pair / USA / big cap
Bryguy / 1 pair / USA / big cap
cwlo / 1 pair / USA / big cap
XO PCB GB Status:
JHClark and wirewiggler, the footprint location for the dayton caps you have is ~60mm x 60mm, with some small breathing room, but I think if you were to mount it at a slight angle you'd be able to fit it no problems.
XO PCB GB Status:
Bkhatton / 1 pair / USA
Russell / 1 pair / USA / Big cap
JHClark / 1 pair / USA / big cap
wirewiggler / 1 pair / USA / big cap
XO PCB GB Status:
bloqhed,JHClark and wirewiggler, the footprint location for the dayton caps you have is ~60mm x 60mm, with some small breathing room, but I think if you were to mount it at a slight angle you'd be able to fit it no problems.
XO PCB GB Status:
Thanks for confirming the suitability of your board to those of us who want to use all film caps - in spite of their larger size. You have performed a fine public service in my view and I "Thank You".
JHClark
XRK,XSD XO PCB (by Bloqhead) GB interest list (only people who have bought the XO kit can sign up). Cost is TBD by Bloqhead but my guess is that shipping and nominal manufacturing costs for larger 2mm thick 2oz copper with ENIG is about $20/pair. Shipping is typically $8 in CONUS, $17 CAN, and $23 everywhere else.
Statler / 1 pair / ?
I've signed up for one of the XO boards because I've only purchased one XO kit. I want to build more of these speakers in the future - but not immediately. Can I buy two more boards now or do I have to buy two more XO kits first? If I can do this, you can sign me up for a total of three boards - all big cap.
My Thanks In advance,
JHClark
Unless X has a problem with it, I am ok with people requesting multiple sets. If anything it will help potentially bring per-board costs down.
XO PCB GB Status:
XO PCB GB Status:
Thank You to blokhed and XRK for concurrence with my question. Please sign me up for three pairs of boards. I want to get these while "the gettin is easy".It’s fine with me.
With JHClark ponying up for 3 pair, that puts us at 20 boards total, $9.06 per board, let's give people some more time to join in the GB.
XO PCB GB Status:
JHClark / 3 pair / USA / big cap
XO PCB GB Status:
Great to see so much interest here. Just hoping people get to build and listen to these speakers soon.
The day approaches for me, UPS has my baffle and woofer cores from your cabinet maker.
Did you just have woofer sections and faceplate done? I was thinking of something along these lines.The day approaches for me, UPS has my baffle and woofer cores from your cabinet maker.
Russellc
Russellc
I did! X's guy is a real deal saint. I attached the most recent picture he sent before it was shipped out. The baffle and cores are glued together, and I think there's a strip of wood added to the bottom of the baffle that's at a 90degree angle so I don't have to deal with 5 degree angles down there. I make the assumption about the strip because it appears there's a small strip at the bottom with grain running a different direction. The cabinet maker wasn't sure if he could fit the base's in the box and as he didn't explicitly state he fit them in, I am assuming they didn't fit, either way. the baffle and cores are the huge road blocks for someone with limited tool access, and no-where near his level of skills.
He also mentioned that the baffles are slightly wider than design to help hide the wings, as well as sent along some tips and ideas for finishing and assembly.
The pricing for materials and labor was very fair if not downright generous, shipping was through UPS and at this point it's all on them
Cool! My thought exactly. I will give a call!I did! X's guy is a real deal saint. I attached the most recent picture he sent before it was shipped out. The baffle and cores are glued together, and I think there's a strip of wood added to the bottom of the baffle that's at a 90degree angle so I don't have to deal with 5 degree angles down there. I make the assumption about the strip because it appears there's a small strip at the bottom with grain running a different direction. The cabinet maker wasn't sure if he could fit the base's in the box and as he didn't explicitly state he fit them in, I am assuming they didn't fit, either way. the baffle and cores are the huge road blocks for someone with limited tool access, and no-where near his level of skills.
Thanks,
Russellc
I would like, if possible, to have the front baffle go all the way to the floor, examples shown seem to have it sitting on top of the base, exposing the edge of the base at the bottom of the panel.I did! X's guy is a real deal saint. I attached the most recent picture he sent before it was shipped out. The baffle and cores are glued together, and I think there's a strip of wood added to the bottom of the baffle that's at a 90degree angle so I don't have to deal with 5 degree angles down there. I make the assumption about the strip because it appears there's a small strip at the bottom with grain running a different direction. The cabinet maker wasn't sure if he could fit the base's in the box and as he didn't explicitly state he fit them in, I am assuming they didn't fit, either way. the baffle and cores are the huge road blocks for someone with limited tool access, and no-where near his level of skills.
Russellc
- Group Buys
- XSD Speaker Crossover and Waveguide GB
