XMOS DSD 384 kHz / 32bit USB
When you specify a frequency it is by definition a sine wave
I was talking about a bass instrument. Wasn't it clearly written?
If you have 440 samples in a second, perfect reconstruction is filter-dependant, but surely it will never be exactly identical to analog waveform, because analog real phenomenons are never "perfect" and never conform exactly to simple mathematical functions. Too many variables.
Then the fact that you said 200Hz is irrelevant. You need to be able to reproduce the harmonics as well so that the sound of the bass instrument is not corrupted
Do you think that if i have to reproduce a bass instrument of - say - 200 hz frequency, i only have to sample it at a 200 hz rate and it will be correctly and fully reproduced?
Ah, so you want to reproduce not just a 200 Hz frequency, but all the audible harmonics too. In that case you need a sample frequency that is twice the highest audible frequency. Thus the 44.1 kHz sample rate.
Thus we are back where this started, "A higher sampling rate than 44.1 kHz is meaningless since frequencies above 20 kHz can not be heard by anyone."
It's not that simple. 90/100 khz is a better limit IMHO, because hearing is - again - a complex phenomenon. And between pure math laws and practical/technological problems there is a substantial gap sometimes.
But sure, i think that more than 300 khz is a total waste. Maybe - but i don't know it for sure - someone wanted a large margin to make up for practical faults.
Anyway, you sometimes find 384 khz files to play, so being able to do so can be "convenient"... 😉
I was trying to find a link that was posted on this site to a YouTube view which explained this very clearly, I'm having trouble finding it, I believe it was in the last month or so, it was by someone who designed digital amplifiers and explained why very high sampling rates are not necessary. I don't think the poster got many or any replys......I wonder why.....
All of you forget digital noise..
Consequently we had sharp digital filters, and analog reconstruction filter, both have influence in sound..
If sampling rate in start was couple times greater, sound degradation of filters will be lower..
In the beginning they don't know what is jitter, can't be expected to realize benefits of higher sample rate ..
https://people.xiph.org/~xiphmont/demo/neil-young.html
