Hi, I'm going to try and build Pedja's DAC.
Am looking for a TDA1541A and CS8412-CP - please let me know if you have some to sell.
Also, are there meant to be some special versions that are better than others?
Thanks.
Thanks.
Hi Cartman, I emailed you.
Ymwong - can you e-mail me please with info in the CS8412-CP?
Thanks a lot! P.S. I asked first!
If you think, you can use the CS8414-CS with an adapter instead of CS8412...
The 8414's sound is better on 44.1kHz (CD), and the price is great...
(about $10) and pin-compatible...😉
Hello Cartman,
Good hint. I wonder how you did learn that the 8414 does sound better for CD.
Could you point out a European - or other - source for the 8414 complete with an adapter?
Best regards, Arjen.
Hi Arjen,
I saw in a topic so somebody tried the CS8414 instead of CS8412, after ELSO KWAK also tried that, and sounds better...😉
I found a very nice price of CS8414: $2.40
look: http://www.futurlec.com/ICSFOthers.shtml
I don't know any european seller, only the farnell, but this is very expensive...about £8...
I made the adapters for myself...it is very easy...but you can find from BrownDog...(http://cimarrontechnology.com/)
cartman
cartman
Hello Cartman,
Thanks for your kind reply.
Interesting option; I first might need to train my skills to solder smd. An smd-capacitor for decoupling here and there I can manage already. I'll search for some hints on the forum.
CS8412
Hi Buddha,
I cannot email you through diyAudio either. If you are still interested, please post your email in some way and I will contact you.
Thanks....ym
Hi Buddha,
Thanks....ym
