As title,
I have 1 driver needing a recone. I can either find another in need of reconing (will pay £35 inc postage) or will buy a pair of good used drivers for £300.(inc postage)
Don't mind buying the 8ohm version either.
Rob
Rob
Hi Al,
'fraid not - said he had 1 used in stock, no chassis available.🙁
Looking at the beyma lx60 15" as an alternative. What do you reckon?
Rob
Rob
Check out this site
Check out this site. It offer the 2226H 8Ohm version or 4 ohm close to your price. With the exchange rate of sterling being so high against the dollar.
http://www.usspeaker.com/15.htm#JBL
Hi Gengis.
Unfortunately it would cost about $140 shipping, and then 17.5% VAT and import duty aswell. Will bump the price up to what they cost new over here.
Thanks for trying to help though.🙂
Rob
Rob
Rob
Those Beyma drivers are used in many 15" PA scoop bins, including some very big names, so you won't really go wrong.
IIRC the Fs was in the mid 30s, but I remember a huge, (for a PA driver) amount of excursion), so you might be able to get away with a bit of EQ to lower the response.
Hi Al,
Believe it or not I'm planning sealed enclosures.
(THX type mids) - they model to a F3 of ~70Hz. I'll be using my tempests below, and hopefully will be building a couple of labhorns over the summer to replace.
Cheers
Rob
Cheers
Rob
Cool!
You might save a bit of money going for the LX60 12", much the same driver, just a little less displacement.
Problem there is the F3 - nearer 100Hz on the 12" I'd need to eq up the roll off, which adding to the 2dB lower sens of the 12" would mean a loss of approx 4dB - more than double the amp power, for the same spl as the 15"
Oh, and 15's look cool😀
Cheers!
Rob
Cheers!
Rob
RobWells said:Oh, and 15's look cool😀
I can't argue with that! 🙂
What sort of box size are you looking at?
