A set that I mentioned is two amp boards (one PCB with a scoring line) and same size single PS board. If someone needs additional PS board, that would be extra.
The amp boards will be sold close to the cost, probably $5/pair or so. PS boards will be sold at $15/pc or so, as this is my design and I can set the price accordingly.
Of course this is still subject to my actual cost from PCB house.
There isn't yet, but the PS board will work with all type of rectifier diodes (2 pin, 3 pin, TO-220, TO-247). It is good for symmetrical supplies, with one pair of caps per rail and series resistors for passive filtering. In place of resistors one can install regulators (LM78XX, LM2937, adjustable LM317, LT1086 and their negative counterparts all will work here). There is also enough space for regulator's heatsinking.
The board is also ready for 4 pole Jensen caps, where their advantage can be utilized (after cutting some traces).
apassgear said:Will these boards be to the last mod done by Nelson? r0 he calls them
Yes, they will.
Thanks, Peter.
Dumb question. If I want to build monoblocks like Steen, will I need
The price should not exceed $20 for two amp boards and PS board package.
4 amp boards and 2 PS boards?
Can somebody start a group buy Wiki on this so Peter can keep it all straight?
Lyndon
Salt Lake City
Slightly off topic: Steen was saying he thinks we need a powerful preamp to drive these. I have been working a year on my 12b4 linestage. Will that have enough juice to drive it?
Lyndon
Salt Lake City
LuckyLyndy said:...............................................
you can expect max. amplification factor of 5,5 ,little more than 14db......
all depends what spks you have
Choky, er Mr. Zen Mod
I have similar speakers to Steen. I built those ProAc 2.5 clones with a killer X-over. They are not too sensitive at about 86 dB. I first built the Aleph 30, and it was alright, but they responded much better to the Krell KSA 50 project.
Thus, I was just reflecting on what Steen was saying about doing a monoblock version of these. Or maybe biamp the Krell for the bottom end and the F4 for the mids and highs?
LuckyLyndy said:If I want to build monoblocks like Steen, will I need .............
2 amp boards and 2 PS boards.
This will be probably $30
If someone wants to open WIKI for amp board group buy, it's fine with me.
Assesears said:I was wondering where the order page is.
There is no order page and I usually work without one. I also won't start collecting money untill the boards are here.
As I mentioned previously, if someone wishes to start a Wiki page, it's fine with me.
Peter said:
Put me down for that, Peter!
And always, thank you for all you do on this forum.
Lyndon
Salt Lake City
2 amp boards and 2 PS boards.This will be probably $30
Lyndon
Salt Lake City
