WTB: briangt chipamp.com CCRC power supply boards
Necromancing this thread
Sent a couple of PMs to those that responded previously.
I am similarly searching for some of these black briangt ccrc boards.
Please let me know if you have any more to sell here or via PM.
CN - if you can't find those exact boards, I recently made a run of CCRC boards for some amps I'm rebuilding with tight footprint inside. Perhaps they could work for your build?
Both are CCRC, fit 35mm / 10mm pitch caps, fit on 10mm grid bottom plates, and are 154 mm x 76 mm.
One is a dual rail, with center tap option.
The other is 2 single rails with the rails running in opposite directions to keep PSU to amp board wiring shorter and symmetrical.
I used 5W resistors that stand up to save space for this layout, take note on that.
Rectifiers aren't on board...
PM me if you're interested.
  • 6 Pack CRC Power Supply v1.0b.pdf
  • 6 Pack CRC Single Railx2 Power Supply v1.0a.pdf
Hi rhthatcher
Those look very nice...as does your Aleph build.
The main reason I am looking for these old briangt boards is because I already have one pair partially populated that I got in a box deal from someone on the forum who got out of the DIY scene.
I want to build a few pairs of stereo amps to play with mult-way active speakers.
I’d like to have matching boards.
I got a few responses...committed to one pair already...still working on a second pair.
