Hello,
Is anybody interested in DCX with integrated 6-channel volume control? I've taken out the DSP board and power supply because I use them in my power amp. It takes you 10 minutes to plug in the DSP and supply from an other DCX and here you are you got a volume control.
But perhaps you are interested in the remaining components only (front I/O, analog I/O, housing, ...).
I've got 3 of these DCX:
1. With 6-channel volume control (Euro 95)
2. With 6-channel volume control and modified analog output (better Silmic caps, one opamp stage ommitted) (Euro 95)
3. Without volume control and disassembled analog I/O (Euro 29)
The volume control doesn't support balanced output because it's a 6-gang poti, but I think most of you use unbalanced outputs, so this is no issue. The 6-gang potis are selected and optimized with external resistors for less than 0.3 dB gang error!
The DCX come in original packaging and original documentation.
I'm interested in 3 DCX with full mods.
oettle said:Hello,
I very much doubt the old GB will ever be going ahead as DIY_Newbie hasn't been online for over 6 months...
- Group Buys
- Would anyone be interested in a group purchase of DCX or DEQs?
