Gaincard ,wrong picture maybe
The cuts in that picture are from Final labs music-6
You know what I'd do with that thing? Once I checked that it operated and that there were no bare-wire shorts anywhere, I'd put the whole thing in a bucket, and pour two-part high-temperature clear epoxy over the whole thing, with only the heatsink sticking out. Then I'd carve into it with a chainsaw to carve out the amplifier as one solid block, then sand the sides flat with finer and finer sandpaper, then wet sand it for a mirror-smooth surface.
Call it a work of modern art.
