Stop the betting crap and measure! If you look at the TL drivers specs it has a beryllium dome with a low Fs of 560Hz and higher excursion 1.2mm p-p than any other Be dome driver I have yet seen to date. It's MMS is 0.27g which is inline with the best Be tweeters out there.
BTW carbon has been long known to store energy, poor choice to start with.
The comments on the RT4001 are typical when not used properly eg crossed too low. Once equalized and crossed properly it does quite well, but alas not top of the line and nobody should expect top of the line performance from a $60 tweeter. It does much better when coupled to a waveguide. The biggest gripe I have with it is inconsistent specs from one driver to the next. I got lucky with two that are very well matched.
IMO the RAAL is best suited for use as a super tweeter
FYI I'm not looking for "the absolute best", just within that "you cannot perceive the distortion" e.g. <0.25%. My setup is typically active, but depending on what I test or design is a combination of either active, passive or both. There are more design aspects than just flat response and low distortion when designing a complete speaker. CTC spacing and dispersion play a critical role too.
RT4001 is the best bang for the bucks i know of. Can't argue with that. And i did not.
But this is the World's best tweeters thread, and i don't think the RT4001 can have a place on the podium.
So far, i think the Top 10 would be filled with all the RAALs, maybe one Scan-Speak, the Dynaudio Esotar, maybe one of the Beyma AMTs and maybe one of the Tlab.
Never heard any plasma, though. So maybe a plasma.
Heard the great Heil, very interesting driver but i'd rather go with a Beyma or one of the top domes for a similar ''soft'' feeling....
That being said, the REAL test would be to try to spot them in a ABX blind test. Mono front-facing test, for the tone/FR, then in stereo for the imaging/dispersion, etc...
To be clear, that's your own personal podium, isn't it?
Better bang for the buck is the Tianle AMT
https://www.madisoundspeakerstore.com/air-motion-transformers-amt/tianle-amt65-4-3.5-amt-tweeter/
@ $10 less than the RT4k1
Yes, absolutely 🙂
That is just my personnal opinion.
Worthless if i fail to spot them in an ABX test.
If i were to organize a proper blind test, i'd test 2khz for both AND after 3khz for both. Not 2/3khz.
Anyway, there is no problem to EQ the 140-15D down to 2khz. 1.5khz might be a problem, but 2khz it's still good.
Just sayin', coz you're in the ''worlds best tweeter blind testing'' thread
I cross mine at 2kHz, but I need a big *** horn for that. And even after getting a flat response, I am not sure it is the best idea. But at the same time I am not sure I want to anything heavier than a alu ribbon from 2kHz and up, after getting used to this setup over period of a year.
Yes, the 140-15D is the true ''RAAL reference'' here
I played thousand's of hours with all RAALs
anyways... 140-15D and 70-20XR are both super-excellent drivers.
Updated list:
Beyma TPL-150 (air motion)
RAAL 70-20XR (ribbon)
Airborne RT-4001 (air motion)
Visaton TL16H (compression horn)
RAAL 64-10 (ribbon)
Tlab N26CFR-A (dome).
Bottomline, RAAL are the world's best transducers for the last 1½ octave, that's pretty much absolute.
Jon, first I want to tank you again for all your work on this project. I also loved your work on the mid-range project thoroughly.
I can see you are very, very fond of the RAAL drivers as well as many other folks and this may be for good reason. However I would really love to see a blind test of a few other ribbon, planar and AMT type tweeters brought into this test or another dedicated test if need be.
I would be very interested to see how some of the following would stack up in a blind test against the "true RAAL reference".
Dayton PT2C
Dayton AMT4
Aurum Cantus G1
Heil AMT
Viawave GRT-145 (maybe reaching on this one)
If the super excellent RAAL stands out among the rest in a blind test I will be persuaded to go down that road myself. I'd like to know if it is head and shoulders above the rest or if it's one of those situations where much greater cost translates to minimal performance increase. Nothing wrong with that of course for a lot of people.
I hope I haven't misinterpreted what you have said regarding the RAAL. I'm just very partial to these types of tweeter and would really like to know how they stack up. 😎
-Rob
I would like to see the Viawave vs RAAL as well.
The Viawave is likely a heavier foil and a more rigid construction overall, however the Viawave will likley measure lower distortion, at least below about 3 khz where it may not matter much in this test?
The rather "highish" measured distortion of the RAAL is fundamental to ALL similar smaller free swing ribbons diaphragms.
I guess it would be between the 70-20XR vs GRT-145. Both can be crossed pretty low, altho the Raal has a much larger foil
Yes larger surface area foil which is necessary for any reliability when using foils as thin as used in RAAL.
I dont know how the 70-20XR is different than the other RAALs but the Viawave has design particulars that can lead to lower distortion in a smaller ribbon compared to a more traditional free swinging ribbon of same size.
Foil weight per surface area looks to be v similarYes larger surface area foil which is necessary for any reliability
can u give link to that info?
my guess is that the Viawave foil is about 2X the RAAL foil thickness
OK did a little searching, looks like the Viawave is actually more like 3X foil thickness over RAAL.
Viawave says .018grams for 700 square mm area, RAAL says .018grams for 2100 square mm area.
This is what I expected based on looking at Viawaves construction and years of prototyping similar constructions as both Via and RAAL.
RAAL is 0.039g 13.6 cm2
VIAWAVE is 0.018g 7cm2
The GRT145 foil is thinner
Hmmm so I look at RAAL 140-15D wich I believe uses same foil as all RAAL ribbons, about 4 micron.
It says in their spec that a 140mm long by 14mm wide is .022 grams
Viawave says .018 grams for ribbon 15mm wide by 50mm long
Thats a 3x difference in mass per unit area
Ive built literally hundreds of similar designs to both RAAL and VIa and I have never seen the 4 micron foil in any configuration last at 1.5 k crossover if it was smaller than the RAAL 140-15D
on the cheap a K-tube and good compression driver can be nice - a 5.3" long section of 1"ID pipe can be used for the tube. Initial gap 1/8" half-ellipse slot. Transylvania used a 2 degree sidewall taper in their tube, partly in conjunction with Karlson's first Acoustic Transducers patent.
http://i.imgur.com/6NMl2KB.jpg
The 2 I'm comparing due to their similarish specs
Viawave 0.009 thick
RAAL 0.012 thick
That number for the Via looks right. MY experience tells me you need foils about that thick to be reliable in a construction like the Via, however the .012 for the RAAL does not look right. It should be more like .004. where did you get the number for the RAAL?
From the Raal homepage:
FLATFOIL? technology: Homogenous field has one, much more interesting result and that is the possibility to use non corrugated, thin, no-excess-weight-sandwich, flat aluminium ribbon. We are using just slightly structurally shaped pure aluminium foil, of just 0.004 mm of thickness, to yield the best possible performance.
- World's best Tweeters Blind Testing
