World's best Tweeters Blind Testing
My point is that any reasonable XO is based on the actual acoustical output of the drivers, not the electrical filters alone. If you are aiming for, say, a LR8 acoustical XO (again, amplitude *and* phase) the electrical filters will be whatever it takes to shape the raw response of the drivers to that target and that will *never* be simple textbook XO filters.
Even with steep slopes your drivers need to have identical amplitude and phase response to about 2 octaves beyond either side the XO point when trying to use the simple 'electrical-only' approach. Amplitude may be easy to dial in, but phase is not.
KSTR,
All that is irrelevant for the part 1 of the test.
Only thing that matters is whether or not participants are able to identify the drivers from each other, in the same room/distance/set-up.
Part 2 is another story, but we're not there yet.
The Klippel test is pretty clear.... though the speakers/headphones used in the test still play a role.
Seems very simplistic and does not account for the way different orders can "mask" one another and what frequency the distortion is peaking etc. Again, refer Geddes paper. I dont want to pollute this thread discussing this here because its a can of worms 🙂
The playback level is one most important variable when it comes to the audibility of distortion with real music signals (read: multitone IMD, not single sine HD). If spreaker distortion is lower than the ear's own distortion at a given level (which is individual, of course), it's inaudible, as a rule of thumb.
Anybody ever listened to something like a flute (recorder) quartet live when you are close? Completely unlistenable because of high ear generated IMD, while the sources sure don't produce any IMD.
Don't underestimate what a room can cause (and hide) in our real world listening situations. (Not meaning to say you do, mentioning this as a general perspective 🙂)
I do agree listening level (SPL) beeing a big factor to deal with. With the klippel test we can control that, and its back to the differences we can actually hear/pick up.
Your preferences may be due to the driver's THD- even if research suggests otherwise- but it may be that other factors are also involved or involved instead, perhaps one or more other design features that correlate with or causally contribute to lower THD.
Slowly begin some preliminary testings...
So far, here's the contenders:
Beyma TPL-150
RAAL 70-20XR
Airborne RT-4001
Visaton TL16H
So two air motion, one ribbon and one compression. I believe we should throw at least one dome, shouldnt we?
The Visaton is very impressive. Out-of-the-box very flat FR.
Here is the EQ i had to make to get a super-flat FR:
8000hz -3.3db Q3.5 Peak
17000hz +2.6db Q1.4 High-shelf
14500hz -1.5db Q5.4 peak
Seems manageable from 3khz but personnaly i'd go from +/- 4khz
Very efficient, pretty decent off-axis response, beautiful construction, reasonnable price for what it is. A great surprise.
