World's best Tweeters Blind Testing
Nah,
It's not sure woden carbon has any advantage in rigidity and weight at these low Sd !
Btw, despite the above discussion about where treble start in relation to the planar drivers (ribon, etc,), I believe a good test is the Triangle : it starts at 2000 Hz and stop around 17 000 Hz! (Frankly, the only serious reason to start a tweeter at 4K is to leave the piano which can have fundamental up to 4k Hz...if only you're a piano lover! For human voices it's a lost cause if you want to go Full Range !
Because the competitors, why not taking if you can the small Be from ScanSpeak ? or a Satori from SB ? And yes why not the Peerless (if it can live with a XO as low as 2000 Hz)!
Updated list:
Beyma TPL-150 (air motion)
RAAL 70-20XR (ribbon)
Airborne RT-4001 (air motion)
Visaton TL16H (compression horn)
RAAL 64-10 (ribbon)
Tlab N26CFR-A (dome)
Can we all agree this dome is a good start?
http://solen.ca/wp-content/uploads/n26cfra.pdf
i heard they are as good as the Scan-speak if not better, but cheaper...
If i were to choose a low-cost dome, that is among the best recognized value... Any suggestions ?
FR between Beyma TPL150H ( dipole) vs Raal 140-15D at listening position. Highpass at 2khz@96dB, no EQ.
