World's best midrange Blind Testing - Need your help.
The first harmonic is the fundamental.
And the second harmonic is the first overtone.
Note that I wrote "the first harmonic to a fundamental". The first harmonic distortion product, the first harmonic overtone to a fundamental spectral component can not be the fundamental itself. The first one in a series ov overtones above the fundamental is naturally the second order harmonic.
And to be precise, the 2nd harmonic is not necessarily the first overtone, but the first harmonic one. With wide band input the first overtone can be a non-harmonic one.
Please also try to understand the context of my post where I wanted to sort out the misunderstanding by Bob Richards that 2nd harmonic = IMD.
Both overtones and harmonics describe the same thing with different terminology.
If you got a fundamental of 1kHz the first overtone is 2k and the second 3k.
If you use the harmonic series to describe the same frequencies these are called 1st harmonic at 1k, 2nd harmonic 2k and 3rd 3k.
There is no frequency called 'fundamental' in a harmonic series.
2nd order harmonic distortion is a product at 2kHz if your test tone is 1kHz.
IMD is not harmonic distortion and Bob was wrong on that one. It is more of a sum and difference thing. These can be part of a harmonic series in rare cases but usually they are not.
The Satori is the typical midwoofers that needs tweeter and crossover correction. There is no way it can pass this midband test even with EQ. The dip around 1k3 due to surround is hard to fix electronically. The elevated HF can be fix using phase plug instead of the default dust cap (which compromises LF, which is not needed in this implementation).
I believe that the real midrange quality will be easily heard when only midband is passed to the driver (ala classics 3-way monitor). With this test of mine, no such drivers like the Satori (including those from Seas, Dynaudio, Focal, even ScanSpeak) have passed this test. They are not optimized for the mid narrow band.
Those drivers above require tweeter in the upper band, and of course crossover correction, or even modification with surround, dust cap (change it into phase plug) and cone treatment.
Most drivers that can pass the midrange test of mine are smaller cheap drivers (but they suffer in SPL/dynamics). My best have been a very cheap 4" with small 2" magnet and 3/4" coil.
But my BEST/FAVORITE midrange is achieved with using 5.25" midwoofer (modified for use as midrange) in combination with a tweeter (ring radiators) of course, to cover the upper band. Yes, there are a lot of works involved as I have mentioned above (not to mention my headache with waveguides).
So, what is wrong with the logic, saying that speaker design is full of compromises and trade-offs such that you can only achieve best performance in midrange if you ignore the performance in lower band and upper band?
Since very long time ago (when classic 3-way monitor is still the only way) we NEVER had a good enough midrange drivers. Now after driver technology has improved, it seems that market demand for dedicated midrange is very small... Only ATC produced one for their own use, of course 🙂
This makes no sense, rambled and arrived at a conclusion that doesn't follow. You say no mid from ScanSpeak, Focal, Dynaudio, SEAS, etc have passed this test. What test? Then you say a cheap 4in driver however is good and, presumably passed this test because you chose it. What test is this that a cheap 4in driver can beat those brands' best mid range?
Midwoofers, not midrange/FR (like 10F). Many of you were surprised why midwoofers like the Satori was "disqualified", weren't you?
Was sitting on a chair. Listening music. Said ''Hell, no''.
[/IMG]
I see. No surprises there, this driver isn't going to sound good unless used correctly. I said this at the start. You cannot generalise in a test like this and come up with answers that make any kind of logical sense.
Anyone I have ever seen write about the Satori (both the 6" and 5" versions) in a subjective sense have said how amazing it sounds but this is only when the drivers are crossed over and used in an appropriately designed system.
Nope.
Using it along with a tweeter and a sub/woofer WON'T change the part he's doing. His bandwith remain his bandwith and he's the only one doing it (i hope..)
If you rely on other drivers to enhance the performance of a mid, then you have a real design problem. Or some kind of budget issue, which is not a problem per se, not just the concern of this very thread/test.
A really good mid, such as the ATC, will also benefit from having a tweeter and a woofer. Its perfectly normal. But even alone, it sounds extremely well...
This post really shows that you have very little understanding of what it is you are actually doing.
Of course it wont, but this is not how we hear.
You do not use other drivers to 'enhance' the performance of the midrange driver you are simply using them to allow the midrange driver to work as it was intended.
Yes and the ATC is completely different in comparison to the Satori. No matter how much EQ you apply you can never come up with a test that will allow you to compare them in a meaningful way if you are only using those drivers.
The only thing you could attempt to do would be to use both drivers in an identical cabinet, so that the diffraction effects added to both would be identical, then bandwidth limit both of them to cover exactly the same range. This would mean using a 4th order acoustic high pass at 400Hz for both and also a 4th order low pass on both at around 2000Hz.
A Good Way to test is. Play a sine like 1 KHz, adjust volume to a fixed level (like 90 dB) make a note, do this to all your drivers. So you have a catalog and volume settings. Now listen to all drivers at the correct volume setting with white noise. The best an most natural sounding driver will most likely be the one that sounds the least aggressive.
ATC SM75-150 Midrange
My goodness, for $580, the ATC better sound good. What is so special about it versus another 91dB driver that covers 380Hz to 3.8kHz? Is there a lot of just reputation and myth here?
ATC as measured by Zaph:
Similar Tang Band 75-1558SE dome mid:
Is there something here to justify the huge price differential over the Tang Band? Perhaps the Tang Band 75-1558SE (circa $175) should be added to the list if the ATC is the current King?
http://www.parts-express.com/tang-band-75-1558se-3-textile-dome-midrange--264-857
The fashion police might 😀...
Probably the reality good pointed out, some listen with the eyes but then give it some clothing on if its a problem 😀.
.....I never warmed up to that white cone, black dust cap look...
But you have the 10F as well BYRTT, do you like the TG more?
If we forget about sound agree in taste and prefer the black ones as 10F or TC9FD in my eyes TC9FD has fancy frame too. Know i expressed had TG9 on order but pulled it last minute had to rearrange finances at that time but soon will reorder. TC9FD and 10F are great performers for me but here in thread cost is not a parameter and expensive drivers are on the list therefor expect TC9FD to be run over and comment pointing to it was meant as joke.
The above needs clarification.
I agree with the above if the tweeter is working outside the midrange frequency we are studying. For example, we are studying 500-5kHz, then adding tweeter from 5kHz-20kHz is irrelevant. And that is the point. We only care with a narrow band where problems usually occur.
But in my case I have stated, I found the best midrange from using two drivers. It means that the narrow band is to be divided into 2 parts. For example, if the narrow band to study is 500-5k, I assign 500-2k5 to a midwoofer and I assign 2k5-5k to a tweeter. Many designers avoid this complexity and assign only one driver to cover the sensitive bandwidth.
Speaker design is full of compromises. The worst compromise is the designer himself. So if making a crossover is difficult, better purchase FR speakers.
There is a reason why the midrange bandwidth is to be divided into two parts. Because each part requires different driver characteristics! For life-like dynamics, I don't think small drivers (including ATC) is sufficient. ATC has slightly bigger than usual waveguide, but I think the life-like dynamics require much bigger waveguide. I even found that my 5.25" is not sufficient to produce the believable scale in mono, but in stereo they are just "fit" nicely.
So here we go for the first pre-selection run:
Scanspeak 10F/8424G00
Vifa TG9FD1004
Max Fidelity PR4neo/8
Fane STD.5FRK
Visaton Ti100
Visaton B80
Fostex FF85WK
Will slowly start to test them while they break-in a bit... I'll take the preselection process seriously and will ask for the help of other ears. It won't be too vindicative 😉
Also for each one i'll try 2 or 3 different bandwith, even a very limited 500hz-2.5khz or so, just for the sake of experimentation.
