World's best midrange Blind Testing - Need your help.
My preference, yes (both treated). FE108eS would make a good midrange thou. A bit soft on the top and needs a big box to do any bass.
dave
I just started to look into my music excerpts:
seems to have a lot of peaks between 400-500hz and 1,200-1,600hz in about half of them.
That might be a problem if we're forced to use xover points above 400-500hz... I'm thinking mostly about the Radian. The ATC i'm not too worried because i know it can work very well down to 350hz with a steep slope xover.
Also small cones might be an issue since we won't use any exotic enclosure to extract max low-end from them...
If the final high-pass xover is above 400-500hz i'd say we'll have to find different music excerpts.
What about choosing drivers that can reproduce midband instead of cherry picking music for drivers that can't?
there is the ''1m distance'' to take into consideration.
that's a darn short distance to hear a singer shout, i'd say.
Check this:
http://lib.tkk.fi/Diss/2010/isbn9789526030746/article1.pdf
77 to 92dB A-weighted seems to be much more realistic, and that includes peaks.
No, it does not include peaks. From the same document.
Utilizing noise dosimeters, Sabesky and Korczynski measured the individual noise
dose of the Winnipeg symphony orchestra members
(6)
. Equivalent continuous sound
levels varied at group rehearsals from 88 to
90 dB(A), in the orchestra pit from 85 to
86 dB(A), and on the main st
age from 82 to 88 dB(A).
Peak levels exceeded 140
dB(A).
we'll have to cherry-pick one way or the other.
at least, with the music its more fair for all the drivers.
But then again, should we be fair with all the drivers ? At the possible costs of losing useful information ?
I mean: if one is able to reproduce correctly a larger bandwith, that's a benefit, isnt it ? That driver as an edge over the other ?
finally and importantly: how this will affect the conclusions ?
Is more energy/natural ease in the 400-500hz will automatically give a more positive perception to the testees ? Same for the 4khz-7khz ?
again we are stucked with the sensorial perception thing.
So let's all agree that 140 dB @ 1khz is painful (it is.)
Now, what would be the exposure time needed for the pain to build-up ? Is 8 milliseconds would be enough ? 200 ms ? Or more like few full seconds... ?
If the ear/brain has not the time to fully process the real effect of 140dB (or 110dB) peak, then why bother with it in our specific case ?
But there is a set of assumptions that what we objectively measure is important. That is a subjective assumption because very little has been done to correlate what we measure to what we hear. For instance Geddes -- once a strong proponent -- of low measured distortion inloudspeakers would now have us toss that out as irrelevant. His take based on real scientific experiment.
dave
Yea, and that is the reason he only use small 5" two ways instead of using 12"-15" mids and subwoofers? 🙂
Anyone that call nonlinearities of speakers irrelevant is either clueless or has an agenda.
