World's best midrange Blind Testing - Need your help.
but what happen if ''favorites'' and ''realistics'' gives opposite answers ?
What's wrong with that? Many think that tube amp sounds more realistic. But what if one favors minimum distortion? (distortion is usually the trade-off or compensation for some variables that relate with "realistic sound").
If the response is equalized, whatever the result, I would prefer choosing my preference driver based on some "numbers".
Any "number" on non-linear distortion? (are they all below "threshold"?)
No rules, no limits, come on, the sky is the limits, yes?
Eq flat to the intended bandwidth and compare at various volume levels. Seems pretty straight forward.
+1 No limitations, use as much EQ is as needed to get the job done. Just be sure to let us know what You did once You have the results.
Maybe the $200 driver only needs 2 bands of EQ with 1.5 dB adjustments, and the $50 driver needs 7 bands varying up to 6 dB adjustments. The conclusion might be they sound very similar indeed. But someone could still opt for the $200 driver, because that would work better in their system, if they are not into the hardcore DSP thing. 🙂
What would be interesting, would be to have one listening session with Jon's rig and another with Tomahack's rig... :nod:
I agree, just make sure all the drivers curve the same, flat or not.
I am very interested in the result. How much difference is between the drivers after dsp with the same curve?
Wow, what a day.
We go from ''no EQ please it's too advanced for us folks'' to ''your EQing is not enough''
The EQ you propose is bound to include room artefacts. An REW sweep smoothed 1/12 would too, if you don't use any type of gating.
So I'd call it 'over use' of EQ. Or: "Hammering the response into shape".
Correcting for driver and room as if it were one "feature".
Wesayso, i can see you're kind of worried about it, but you shouldnt be. Really.
Again: 400hz-7khz band + nearfield measurements (around 2m distance) + large room + moderate SPL... I'm very confident we won't have to ''hammer the response into shape'' because of the in-room situation.
an anechoic chamber wouldnt be any more useful, on the contrary.
Our environement will show something closer to real-life, repeatable context. The distance from the center of the driver to the floor will be approximately the same as anyone would do.
And, more importantly, ALL the drivers will be compared in/with the very same environment, context, equipement, measures, etc...
Which means they will sound very similar 🙂.
Nobody mentioned the need for an anechoic chamber. But you could easily use a REW sweep and gate that with a frequency dependent window (of about 1/6 octave) to leave the room out of the equation as much as possible.
EQ it like that and all measurements taken without gating will look a lot cleaner. This type of EQ will sound better off axis too as it isn't as fixed to that sweet spot.
Agree.
