Wobbly CD Transport Output
Hi All,
I have had a search but had no joy. Does anyone recognise these symptoms?
:scratch:
Audible background fluttering sound to the music playing, the more complicated or louder the music becomes, the more muddled the sound.
Would you think this is a transport problem, or something a little less expensive?? Perhaps it is a jitter caused by the clock synch input from the separate DAC (like a clock mismatch)?
Any pointers will be welcome.
:scratch:
All the best
Jon
Either you use the digital out and the coax isn't properly attached (or runs too close to some mains wires - interference) or the puck is no longer balanced. Also you're digital in could be a bit to sensative to the signal strength it receives. Just some thoughts.
Thanks very much.....
that's definitely something to go on.
I was also wondering if a transport motor can waver (ie hunt around the required rpm) and create a wow like an old record player.
A new transport is going to be about 70 GBP.
All the best
Jon
