Hi All,
I have had a search but had no joy. Does anyone recognise these symptoms?
Audible background fluttering sound to the music playing, the more complicated or louder the music becomes, the more muddled the sound.
Would you think this is a transport problem, or something a little less expensive?? Perhaps it is a jitter caused by the clock synch input from the separate DAC (like a clock mismatch)?
Any pointers will be welcome.
All the best
Jon
All the best
Jon
Either you use the digital out and the coax isn't properly attached (or runs too close to some mains wires - interference) or the puck is no longer balanced. Also you're digital in could be a bit to sensative to the signal strength it receives. Just some thoughts.
