When I upgraded to Win8 from Win7 because I got in soon I was given a £25 upgrade package. It was just a download.
you have a year to migrate your old windows to a new hardware platform + OS upgrade, after that all bets are off. IMO get a backup or HDD image before the years is up and that should hold most folks.
I downloaded w10 on to a USB drive.
The version I downloaded does 32 and 64 bit.
I run both on my pc on 2 separate drives. The 32 bit still runs old 16 bit software of which I still have a couple of programs I still use a lot.
Win 10 update failed when I tried it a couple more weeks ago. Anyone know if the dual graphics cards, dual monitor, nvidia bugs have been fixed?
There s currently some unidentified issues when using Windows10 and Nvidia 353.62 driver, Alienware recommend not using this driver with their laptops.
Win10 + 353.62 Drivers are Killing Samsung and LG Notebook LCD Display (geforce.com) - AnandTech Forums
Katherine Albrecht: Windows 10 Is Full Blown Electronic Tyranny - https://youtu.be/GLiozMpqV80
In case you don't know who she is, Dr. Katherine Albrecht https://www.startpage.com/eng/company-management-bio.html About Katherine | Katherine Albrecht
https://www.startpage.com/eng/protect-privacy.html - https://www.startpage.com & https://ixquick.com
In my experience, a new CPU sometimes will be accepted (AMD & W7) as well as additional Ram (very likely to be accepted).. A new MB indeed is stretching the limits too far, for too many HW components change.There's a limit to what you can change on a Windows PC before it objects that its now totally different, so a new processor and new MB and RAM is way beyond that limit. Its a totally different PC 😉
Not surprised it won't activate tbh.
+++Katherine Albrecht: Windows 10 Is Full Blown Electronic Tyranny - https://youtu.be/GLiozMpqV80
I don't know whether this has been mentioned but the W10 update keeps badgering until you inadvertently click on Windows Updates and it is done without your full realisation.
I stopped the nagging with a registry entry and it has killed the nagging completely. if anyone is interested, please let me know? (As always, the disclaimer is that registry changes are not for the fainthearted.)
If you manipulate the registry (KB3035583??) please mark it in the windows updates as HIDDEN, otherwise it comes haunting you.. 😡
don't forget to also remove the download directory of W10... saves up a lot of space..
Is that the one called " C:\$Windows.~BT "?. . . don't forget to also remove the download directory of W10... saves up a lot of space..
Dale
Any guess as to when it will become impractical to continue with Win7?. . . all running very stable W7 pro, and they will stay that way for as long as possible . . . .
After stumbling down the Win95 - Win98 - Win98SE path, where it seemed like each new turn fixed some problems but created other problems, I switched to Win2K. The change wasn't entirely voluntary but I quickly came to like Win2K A LOT, and stuck with it until I completely replaced the computer in late 2009 - almost 10 years. (In retrospect, I probably should have switched to Win XP but I was reluctant to abandon an OS that worked very well just to get some features of unknown value, and risk acquiring unknown performance problems.)
The new machine had Win7 already installed. Although I seriously considered wiping the hard drive and installing Win 2K, I was soon won over by Win 7. Every major program or utility I had previously used under Win 2K installed cleanly and ran right off under Win 7, and Win 7 obviously exploited the new hardware in ways Win 2K couldn't even dream of. The number of Win 7 Updates coming from Microsoft is a little annoying but I don't see any good reasons to change OS.
So how long can do you think Win 7 will be viable, even if it's not fashionable?
Dale
Dale
probably as long as Win XP lasted, unless MS or a partner creates a killer app that requires a change of OS. ~ 4 to 5 years more ("viable" is debatable considering some fella just posted a thread about making his brand new PC with XP)
Dale
Log files ? This was for Vista.
https://support.microsoft.com/en-gb/kb/928901
I don't know, Dale...Is that the one called " C:\$Windows.~BT "?
Dale
The download directory should have a size of some 5Gb, so I've read.
Fact is, I killed the KB3035583 update long before it was able to download anything..
W7 will remain useful as long as MS allows it to be. XP lived a lot longer than it would have because of large corporate clients.
I worked at Motorola for 41 years. We used to have our own in house IT department that controlled all the PC's on the corporate network. XP corporate edition and only XP corporate edition was the only MS OS allowed on the Mot network for years. Only ( about 5) specific hardware packages were allowed. The corporate edition did NOT respond to MS updates, all updates were tested by IT on our hardware, and then delivered to the individual PC's on the weekends. Once a month there was a PC shutdown Sunday where your PC could be expected to reboot several times. MS still supports this mode for large corporate clients on W10.
The issue with XP is that the 64 bit version was never really properly developed or supported by MS, so all of our XP machines could only access 3.7 GB of memory. This really sucked for the simulation guys. All of the Cadence IC design tools were migrated to Linux boxes with huge memory banks. The ADS guys were stuck with day long sims. One of my co-workers had 4 PC's, 3 for ADS sims.
Mot transitioned to outsourced IT and W7 was allowed. MS announced
"the end of support for XP" and W7 machines started appearing in the plant. W8 machines were never allowed on the Mot network. Somewhere around Christmas 2013 there was a malfunctioning W7 update that killed dozens of machines. The PC was corrupted and less than knowledgeable users (who didn't know what FORMAT meant) lost their hard drives. MS and our new IT company went rounds and rounds, and XP lived on in the corporate world. I was still using my 10 year old Dell XP box when I left the company last year.....in fact XP is quietly still supported my MS for some large clients like banks and the US government. Why? Many ATM's and POS systems still run XPE (XP embedded).
I had subscribed to MS's IOT (Internet Of Things) program and tinkered with XPE. Guess what offer I got from MS a few weeks ago? Yep, a FREE download of W10E, but only for two specific hardware platforms, one of which is the popular Raspberry Pi 2.
Windows 10 genisys app get it now,
For total connectivity
https://www.youtube.com/watch?v=jNU_jrPxs-0
M. Gregg
M. Gregg
It's only application software that prevents you using even Windows 3.1 machines. It depends on what the PC is used for. If you never need to upgrade any of your applications then your old computer will live forever, or at least until electronic failure.
Any hardware failure will be pretty terminal.
I've had instances where the OS has ultimately given up with such simple upgrades as adding bigger HDDs.
Are you happy with This !
Scary Analysis of Windows 10 Confirms Privacy Concerns
Are you still trying to stick to the optimistic side of the game waiting for Microsoft to somehow save its face when it comes to Windows 10 privacy concerns? Latest revelations might help you rethink the way you trust your Windows 10 powered machines
It doesn’t seem to matter if you use a Microsoft account to log on to your computer or not, the operating system sends your data no matter what, including your passwords.
Following are the instances reported by the analysts where it was discovered that data was being sent to the Microsoft servers:
* Text entered is stored in temporary files and an encrypted transfer is made once every 30 minutes to the following servers:
o oca.telemetry.microsoft.com.nsatc.net
o pre.footprintpredict.com
o reports.wes.df.telemetry.microsoft.com
* The analyst found 35 MB of data being sent to the servers after the web camera was turned on for the first time after Windows 10 activation.
* It is further confirmed that the data from the voice port is indeed being transmitted even when Cortana is disabled. Over 80 MB of data is sent once every 15 minutes, when the computer is idle.
With previous versions of Windows I just phoned up to reactivate Windows.
You can only do tha with a RETAIL copy Windows 10.
While they weren't very clear about it earlier in the year, it's been known for months now that there are limits to what hardware can be changed with the upgrade.
If true, very shocking...😱
More food for thought/Action !
If you know how to, then these could Very useful to help disable the Spyware in W10.If you don't, then the earlier Free Apps i linked to will enable you easily to disable some of them 😉
Disable Windows 10 telemetry - Pastebin.com & http://pastebin.com/raw.php?i=LjxW3yAA
@ esgigt
Yes they are TRUE !
More than shocking, Disgraceful. Why anyone would "update" to W10, or buy a new comp with it on, after knowing how it spies on you etc, is a mystery to me ?
Even when told not to, Windows 10 just can’t stop talking to Microsoft
It's no wonder that privacy activists are up in arms.
http://arstechnica.co.uk/informatio...indows-10-just-cant-stop-talking-to-microsoft
@ esgigt
Yes they are TRUE !
- General Interest
- Everything Else
- Windows 10
