Windows 10
I was running a simulation with Multisim 12, paused the sim and stepped away from the machine to do some measurements. (It was something like 2:00 a.m.) When I had come back the computer had "reset", shutting down Multisim in the process. All this for a Windows 10 update.
That's what happens when the operating system is more important than the work being done..Ie Microsoft owns your PC.
M. Gregg
I'm running a GTX970 with dual monitors and it works fine.
If I try to add a third monitor to clone my primary the computer will recognize the third monitor but I don't get any picture.
This 3 monitor setup worked fine on windows 7.
I suspect there are still some bugs.
There's a limit to what you can change on a Windows PC before it objects that its now totally different, so a new processor and new MB and RAM is way beyond that limit. Its a totally different PC 😉
Not surprised it won't activate tbh.
I have never had any problems reactivating with previous versions of Windows despite full upgrades.
It looks like Microsft is trying to stop people moving on their copy of Windows to a new pc but as a side effect it is also catching out upgraders.
I guess what I will have to do is buy a cheap copy of Win8.1 or Win 7 then upgrade to Windows 10.
I really do not understand why you guys are so keen to suffer v:1 of a new OS!
I have multiple PCs all running very stable W7 pro, and they will stay that way for as long as possible. Everyone is imaged on a server.
However, I might make a W10 upgrade within 12 months and store a snapshot of that for future use 😉
I don't think anything has changed with regard to this. Whether its an 'upgrade installation' or a standard install, activation will fail with all those changes. If your starting point was a full retail version of Windows (not an OEM copy) then you are free to reinstall it on any other machine (and bring that up to qualifying W10 upgrade status) as long as only one machine is licensed at any one time.
you have a year to migrate your old windows to a new hardware platform + OS upgrade, after that all bets are off. IMO get a backup or HDD image before the years is up and that should hold most folks.
I've never had a problem with that either. I did a whole processor, ram and mobo upgrade a year ago with 7 and all I had to do was reactivate, no issues.
A good few years ago I upgraded my PC.
I also installed a new version of Windows.
I was absolutely horrified to find the Windows installation had formatted both my hard drives first !
I had my most important stuff on DVD but still lost hundreds of pictures and some software.
At least now Windows now gives you the choice of leaving your files or doing a complete clean install.
If its the retail version you can do that. If its the cheaper OEM version then you can't. Once activated the OEM is tied to the that PC
That wasn't always true with W7 or XP. I have always used the cheaper OEM version since I make PC's, and devices that use a PC motherboard for its brain. I have probably purchased 40 or 50 of those OEM disks.
Usually swapping out the entire system or some of the major components (CPU or MB) will trigger the "your copy of Windows is not genuine" warning which usually can be resolved by clicking on the "authorize" link. In a few instances I have had to call the phone number and wait a half hour to speak to someone in India to get an activation code. I always use the story that the motherboard died and I decided to upgrade the CPU (and sometimes the memory) at the same time. Answer their questions with "there is only ONE machine using this copy of Windows", and YES, this machine has the authentication sticker on it.
In one case I told the guy that I had 7 identical W7 machines and I was swapping out the MB, memory and CPU in all 7 with 7 identical sets of new stuff. Intel exited the motherboard manufacturing business rather abruptly a few years ago, leaving me with no choice, and no easy replacement for a battery operated PC.
He had me run some routine that generated a string of numbers that identified the hardware on one machine. He then asked for the string of numbers on each of the 7 "authentication stickers" that comes with each OEM disk and should be attached to the PC. He gave me 7 activation codes, one for each machine, and everything worked.
Back to W10.....My laptop has generally worked OK since it was upgraded to W10, but it will generate a new version of the BSOD once in about every 10 power on's. A black box will pop up telling me that "Windows has encountered a critical error, Cortana and the start menu did not start. We will try to fix this on your next restart" The restart happens immediately.
