Wima MKP2 vs. FKP2
If it helps, and it probably won’t, I upgraded from Wima MKP2’s to FKP2’s not even on signal on filter caps on an analogue supply and they were better. More body and better tonality, more real and natural sounding. Dynamics were as good or better. The only reason I changed was it was cheap and reading the Wima brochure they were seemingly a better choice
Not life changing but for a few pounds great value
in today's world of SS electronics, the sheer SIZE of that ... would probably be prohibitive on most circuit boards. ...Nichicon BiPolar ... 63¢
Last time I built something "CLEAN!!" I started with the large input film caps, and let the size be what it wanted to be (even though this had to travel a lot).
But that was for ME. If it was for other people, yeah, an e-cap is fine.
I have seen measurements where bipolars were as good as film caps, distortion virtually immeasurable, even with a voltage over the capacitor. Now, with bipolars you can go to very large capacitances for the input stage. In my present design, I use 22uF over 47 k. This makes the voltage drop over the capacitor miniscule. Since distortion can only be introduced by the proportion the capacitor absorbs from the voltage divider on the input, which is even smaller, the total contribution to distortion is exactly that: something that is almost immeasurably small times something even smaller. Do the math yourself.
A capable circuit designer can get stellar performance from off-the-shelf components, so why use anything else?
To nudge back in the direction of the thread topic: I once compared three 220 nF film caps on an HP 4194A impedance analyzer: A $0.50 Panasonic EF-series, a $2 Solen film cap, and a $20 Mundorf silver-in-oil. The Panasonic measured closer to an ideal cap (lower ESR, higher SRF) than the others. The Mundorf measured the worst.
Tom
Are you talking about Panasonic EF organic polymer capacitors?
I like the FKP1s alot, need to try FKP2. Also like the 10uF MKP4 alot. I tried and eventually came to the opinion I dislike the MKP10.
In fact i’ll have to experiment to find a low leakage/low distortion cap for an ADC circuit for AC decoupling so i’m interested in results (i know it becomes valued info for manufacturers).
