Wima MKP
Mouser also sells WIMA FKP1 Foil/Film caps. They are just a little bigger than the MKP10 series caps and better as they are foil and not metalized like the MKP series. WIMA's are in general smaller than other brands of comperable capacitors.
I've checked Mouser and they don't have the appropriate values in FKP. In MKP they are all listed as 'AC Pulse, Suppresion" that doesn't sound right for aC coupling does it?
They just highlight their properties for SMPS etc. Of course they can couple well when they can store and release high energy with fast and cool action in demanding pulse applications. In industrial capacitors the things they prioritize are different than in boutique audio caps. Form factor, value density, durability, dimensional and spec stability, self healing, all that VS cost. Its their high volume production and professional applications they keep them sanely priced, not the R&D and production facilities behind them ain't top notch. To the contrary. Just not specialized for audio.
Sorry, but I have to disagree here! The old SIEMENS B32650 series of MKP capacitors are considerably (!) smaller than WIMA MKP10's of the same value and voltage rating.
However, I don't know if they're still available...
Edit: This also applies for the KP 1833 series by ERO/Roederstein.
Best regards!
And then some others do, also the land of enough niche small brands besides the famous industrial.
