I'm looking for a sweet sounding tweeter under 50 to 60 bucks a pair that has wide dispersion but doesn't sacrifice quality.
I suppose it's because I've been goofing around with some cheap horns I have but I've come to like the spread-out sound more compared to the "highly directional" Vifas I've used in the past.
Never have heard a ribbon tweeter (Beston?), and what's the deal with these Neodynium (sp) tweeters? -- just looking at their construction, seems I should look at these as well. What about the HiVi stuff?
Can't really use a horn because I don't have the depth in my enclosures.
Also, something in a mid/tweeter would suit my situation ideally.
THANKS.
THANKS.
How low do you want to go?
HiVi RT1.3 is a gem at 2.8-3kHz+, LR4 or higher.
I've used the Beston RT003C, but it goes to about 3kHz at the lowest, and rolls off SHARP below there. These are waveguided, so more directional than the others.
Later,
Wolf
Later,
Wolf
ive had a good experience with founteks' neoCD3.5H WG/Hornloaded ribbon used 3rd order or higher @ 3khz, or 2nd order @ 5khz.
Its wide horizontal pattern and narrow vertical pattern may work for you. Somewhere between the horns you had, and wide dispersion you seek. At 35 euro its also within your budget.
wide dispersion tends to mean small- which tends to mean crossed-over high.
Above your price range are the HiQuPhon, which are 3/4" so have quite broad dispersion, they handle lower XOs than typical <1" domes, and have a very nice sound.
wish I could find something a bit more inexpensive -- the HIVI and Fountek sound like winners but can't spare the money now.
The price is a bit to high but good dispersion and not extreme expensive.
SB Acoustics :: SB26ADC-C000-4
[URL="http://www.eltim.eu/index.php?item=--price-per-piece&action=article&group_id=20000453&aid=157&lang=NL"]http://www.eltim.eu/index.php?item=--price-per-piece&action=article&group_id=20000453&aid=157&lang=NL[/URL]
http://www.eltim.eu/data/mediablocks/Morel%20CAT%20408%20Hobbyhifi%205-11.pdf
Maybe Wavecor is cheeper.
http://www.wavecor.com/html/tw030wa01.html
http://www.wavecor.com/assets/TreeMenu/speaker_units.html#
the Fountek I have are great for the midrange price. They are only a 10mm 3/8" ribbon. Strangely in the datasheet 'dynanvox' is the maker.
There is certainly merit in dome tweeters and the HiQuPhon (of which im oblivious to) are certainly worth a look too.
I find i like both domes and ribbons. A dome like Helmuth linked could be crossed low order, maybe even 1st (or damped LC)
THANKS.
Something that has wide dispersion even at higher freq.s, mid-range usability, and is otherwise objectively *good*: doesn't exist.
Limit the mid-range use and there are few choices..
Still, if you want all 3 then I'd recommend:
Vifa NE19VTA
http://www.zaphaudio.com/temp/Vifa-NE19VTA-FR-offaxis-0-15-30-45-60.gif
*with*:
Vifa TC7FD00-04
http://www.zaphaudio.com/temp/Vifa-TC7FD00-04-FR.gif
IF you don't care about objective performance there are BMR"s:
HiWave BMR12 Compact 2" Full-Range Square Speaker 12W 8 Ohm 299-208
Hi all.
I'm looking for something similar to the object of this 3D.
I can go above 2.5/3KHz.
My goal is wide horizontal AND vertical dispersion.
Which kind of tweeter i have to refer to?
Hi all.
I think I need any 3/4" tweeter out there.
LR4 @2.5/3KHz.
100€/$ the pair.
SB Acoustics SB26STAC-C000-4
Axis: 0 (blue), 15 (green), 30 (red), 45 (purple), 60 (gold/brown).
Yes, it is a candidate.
How much can I push it down on the bottom side?
..depends on the high-pass filter.
With the right filter and withOUT a waveguide, probably 1.8 kHz.
Thank you Scott.
I'm thinking about using a waveguide to uniform the overall dispersion.
Anyway, i didn't find any good priced tweeter plus waveguide combos. Audax tw034 plus jantzen waveguide are high priced for my tastes.
I understood a waveguide can decrease the lower lpf crossover point.
You said that 1.8KHz are good withOUT a waveguide.
Now i didn't understand anymore...
I would like to match dispersion between 8" full-range, crossover point maybe at 1.8KHz, and a tweeter plus 8" waveguide.
Maybe a bit OT here.
I replied to this 3D:
Loading a Waveguide With a Dome
Thank you.
Hi all.
Here is one that you might consider.
It is a 3/4" dome that can be crossed above 3500 hz.
Inexpensive in US, but don't know about shipping international.
Dayton Audio ND20FA-6 3/4" Soft Dome Neodymium Tweeter
Thank you for your suggestion.
In the meantime i changed a bit my mind, as you can see from the previous post.
I better understood dispersion behaviour, and would like to go lower in the crossover point with the use of a large tweeter waveguide.
Yes, i like the bmr idea.
But never heard them, and there are mixed opinions about them out there.
Did you ever listen to them?
Mmm...
3 per way, line array, good vertical dispersion, very wide horizontal dispersion, 89dB but low power.
What about the 3KHz peak?
Maybe @1KHz xo point?
EDIT: 4 per way, 86dB, 4ohm, 20Wrms: really low dynamic.
- Wide dispersion, quality tweeter
