Why Soldering Wire is a Very Bad Idea
How many times does one solder two wires together?
How do we crimp components within a pcb?
I do not see what this has to do with audio gear.
Who would crimp a soldered wire, anyway?
Good crimping tools are very expensive.
Nothing in that shows me why crimping a bare wire with a garden variety crimper and then soldering it could be "bad".
What is the point? Is there a point?
Go to YOUTUBE and see the comments.
I prefer to solder my crimps.
Thanks, Miller-8 for the interesting video. I learned a lot about solder joints. I also think rickmcinnis has some good points - mainly that it's mostly relevant to equipment subject to vibration and temperature changes. Still, I'm going to avoid soldering wires together. This has also inspired me to look into some decent crimping tools.
Reactions: Miller-8
It is not always easy, but making a good mechanical connection before soldering is what I count on before soldering the joint. That is easy when you have the space to do it, but is tricky like a circus when you don't. Do NOT depend on the solder alone to make the electrical and mechanical contact alone. Use the combination of the two for the best joint. Besides you want the two wires to actually in the best mechanical contact, and not just the solder holding everything together. I see this fault again and again. Two straight solid core wires being held together only by the solder.
Reactions: svp
You clearly didnt watch the video properly.
Also crimping tools are much cheaper nowadays, as was stated in the video also.
Well I'm kinda glad I was blessed by growing up in the times of Sn60Pb40. 🙂 but these days finally I understand that crimp is the choice in many applications. I always get angry though when I grab shared crimping tool at work and it's set on minimum force so someone's hands didn't hurt.
Reactions: Ixnay
From the video description:
"This video, description and comments contain affiliate links, which means that if you click on one of the product links, I’ll receive a small commission. This helps support the channel and allows us to continue to make videos like this. Thank you for the support!"
Just click in the Amazon link to buy crimping tools. 😊
