why papa doesnt choose Lateral Mosfets?
If you degenerate the source of a vertical so that it's transconductance is similar to a lateral, does the vertical not then have similar linearity ?
I think the answer to this question is fairly clear. See attached simulation sweep comparisons of a 2SK1058 model and an IRF630 model. A series 2.2VDC source was added to the IRF630 to lower its threshold voltage, and a 0.6 Ohm source resistor to lower its gm in order to closely match the 2SK1058.
I would say contrary, yes. Apparently this sim model requires some minor tweaking, even though it is directly from IRF.
I have run the same simulation again, this time with a more complex subcircuit model of the IRF630. The plateaus are now ruler flat (up to 20V anyway), indicating an Ro=infinity. In reality, there probably is a slight positive slope to all pentode-type output curves.
With a given load line, the lateral has slightly more lower-excursion output swing than the vertical.
But how does the large difference in Ro translate to how the devices will sound in a class A or AB application?
It is only one of a list of factors, among them (to use tubes as an example):
Triode / Pentode
Bias
Load Line
Common Plate / Common Cathode,
Single-Ended / Push-pull
Single Stage / Multi-Stage
Loop Feedback - type and amount
Degeneration
Cancellation
Cascoding
Agreed, but say we take a class A amp designed around the 2SK1058. Then we make a few minor mods (higher bias voltage and added source resistor) and replace it with an IRF630.
Now essentially the only difference is the Ro of the amp (see above output curves).
Assuming we don't push into clipping, how will they sound different?
The decline in popularity and availability of LatFETs has a reason - they don't offer enough of an advantage over alternatives. Tubes and vertical FETs are both still in production and easily available so price (Tubes cost more than LatFETs) is not the main issue.
Agreed.
Lateral fets, ~$22, whereas VFETs are about $4.
Also, in my opinion there is little if any advantage to SITs over VFETs (they can be configured to operate similar to SITs).
Reactions: rankot
