Why kind of Vacuun tube is the Tung-Sol TS 930 ??
I've owned many Kepco supplies and have not known them to use house numbers on tubes. But TS 930 sure looks like a house number. They also look like 7027A's which are just glorified 6L6GC's. Perhaps test one as such. Maybe also trace the internal connections to the base to see if pin-out is the same.
A pair on Ebay. $$$
Looks like pin 1 is grid3, pin 2 is grid 2, pin 3 is plate from the rightmost pic. Which does not match 7027 or 6L6GC. If these got used in Kepco's 550V pwr supply model too, they may have requested a pin-out change for socket reliabilty.
Maybe Twinky101 can verify the full pin-out for these type of tubes?
