why is my Dual 1009 muting in play position?
Turn it over (carefully!). I do not know this machine. Usually you can see a lever on the tonearm shaft hit a switch with audio wires coming out. Yours is perhaps mis-aligned. See if it looks like the lever has been forced past the switch and now working on the wrong side, or if the lever can be loosened and re-adjusted to hit the switch at the appropriate position.
