Sd or the amount of surface area plays a role and when combined with low Mms or moving mass can aid in low volume transparency, in the bass and mid range, beyond that the Fletcher Munson curve works in helping low frequency detail perception.
How much do you want to bet?I'd bet it's 90 percent directivity.
It's 100% a directivity cause
It's 100% a dispersion cause
It's 100% a power compression case
It's 100% a friction/losses cause
It's 100% how the ears catch the sound
It's 100% how the brain processes what the thympanis send
Do you want to bet ?
... I've seen this answered on so many occasions with the advice to seek a high sensitivity system...
Hi ! could it be that for a same SPL generated the more efficient speaker has lower distortion ?
