Not really, I sent him a PM on another forum hehe.
Does someone knows a cheaper 18" woofer than this one?
Parameters are below average at best...
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=290-386
You want something cheaper? your kidding right?
The only way to get something new for less is if its shop soiled or B grade.
Man you must be really broke or cheap😉
Noticed the SPL: 94.2 dB 2.83W/1m
Thats very high indeed.
Frequency range: 30-2,000 Hz
I would suspect the Mms is only 160 to 200 grams including the coil, so this really is just a loud big speaker, it doubt it will make much bass with its very limited excursion, i hate the accordion surround esp when there paper, there just so fragile and nasty.
I just wanted to know if it existed hehe!
Yeah not much bass, that's why I said parameters below average at best. Very high Vas, high Qts, low Xmax, mid-high Fs...
My boss has 2 18's like that in corner loaded TL's (slight taper, triangular profile) very impressive off little power, more suited to music than HT, excellent for live concert DVD's.
Read over this thread...always was under the impression that a driver's inductance and the enclosure environment had far more to do with the transient response than simply Mms.
Adire has two 18" drivers in their new lineup, but who knows when they're being released 🙂
Glowbug said:Read over this thread...always was under the impression that a driver's inductance and the enclosure environment had far more to do with the transient response than simply Mms.
You can work that way and see that transients is more than just Mms alone, the amplification will have an affect to.
I have never heard of Adire.
http://www.adireaudio.com
OEM for a few places, also sells their own stuff. HT and car audio drivers.
They dont have a shop in south LA, i did not see any loudspeakers on there website, do i need a plug in to see the speakers?
Yeah, the website is awful...here's a link to one of their online dealers, has better product photos...
http://www.acoustic-visions.com/~acoustic/products/subwoofer_drivers/index.shtml
That Splinter woofer is very big indeed, odd specs, only 1000 watts power handling with such a low sensitivity coil at 82 db.
I wonder who would buy it and what type of sound quality it has with so much travel.
There kind of expensive or am i really out of touch?
let throw in my .02
I don't know for sure about there retail store, but i got on off ebay for less than 70 shilings+s/h of course. It is from a company called ADIsound, www.adisound.com and no theres no "M" in front. They are model #PD-1800 they model real well in Winisd pro. In a 5.5ft3 tuned to 16Hz will reach 109db at just under 200 watts with not reaching xmax. Forget Goldwood they are like limburger cheese.....yeah it's cheese but it sure smells like shiit. Matter of fact i saw 18's being sold on ebay today for 40.00
simon5 said:Not really, I sent him a PM on another forum hehe.
Looks really good for $70.
It looks like a JBL, how do they sound?
Nice looking company, like a family, not some faceless gaint!
Iron-Wizard said:That Splinter woofer is very big indeed, odd specs, only 1000 watts power handling with such a low sensitivity coil at 82 db.
The RL-s?
It uses TC Sounds' Linear Motor Technology, instead of a "typical" underhung or XBL^2 motor, for example. Supposed to have an extremely flat BL curve, though I've never heard one in real life.
They were quite a disappointment to the car audio folks mainly because of the enclosure requirements - they simply need so much volume and power to get moving. Definitely not a practical design when two "standard" drivers can be used and get more displacement for basically the same price. In a smaller enclosure.
Glowbug said:
The RL-s?
I tried to join your SS website, do i have to pay, i ahve registered but i can not log in?
So how does this TC magnet work, i have never heard of the XBL2 motor, sounds like a rocket from a comic strip 😀,
If the BL is flat does this mean it has the same sound quality at low volumes and high volumes? sounds like a good idea.
I can understand the Splinter not being taken on, not many amplifiers can make 1000 watts RMS with a 12 volt power supply and not fry themselfs, that would be better in a truck system with 24 volts. I know lots of truckers but they dont care about big woofers, they are happy with a pair of Pepboy specials behind their heads.
The splinter must be for those compitition guys, more money than sense but somebody has to be mad.
Hmm, is the top bar still orange on the forum? It's a free forum, you should be able to post if your account is active...maybe you need to activate it via email or something.
XBL^2 is a motor topology designed by Dan Wiggins over at Adire Audio, he's licensed it out to several other manufacturers. I'll let someone more knowledgeable than I explain the concepts of BL and motor strength, as it's not something I'll probably do a good job of on 2 hours sleep 😀
You'd be surprised at how many kW+ amps there are for 12VDC. The problem is, most drivers don't *need* a kilowatt to really get moving. It's also a SVC 3 ohm driver, and therein lies a bigger problem. A 1000 watts @ 3 ohms is a different ball game in the mobile electronics market than 1000 watts @ 1 ohm nominal.
Check this out.
How about blurry vision at 200 watts. Its not stamped either, the basket is solid. The whole thing weights around 45lb it is a sweet driver. Later Ken
Iron-Wizard said:Looks really good for $70.
Iron-Wizard said:Who said there stamped?
At 45Ib they should have used a stamped basket to lower the weight😉
No one said that, it was just for common knowledge.
I absoluetly hate stamped basket at real low hz they have been known to vibrate, and thats not good in my book.
- Subwoofers
- Why are there not many 18" subwoofers available?
