who's using the Karlson tube waveguide?
Tweeter waveguide ? its among my favorite for sound quality
Karlson's X-15 speaker system which used an internal slotted pipe tweeter
it looks like Walter Zintz's Transylvania Power Company ads started around 1979 (?)
http://www.americanradiohistory.com...nd-1984-11-OCR-Page-0037.pdf#search="karlson"
http://www.americanradiohistory.com...OCR-Page-0094.pdf#search="transylvania power"
http://www.americanradiohistory.com...OCR-Page-0012.pdf#search="transylvania power"
http://www.americanradiohistory.com...OCR-Page-0088.pdf#search="transylvania power"
http://www.americanradiohistory.com...OCR-Page-0112.pdf#search="transylvania power"
one thing I've not tried - - take the pipe, slice it at an angle. Glue on a flat piece then cut the aperture. This by Karlson theory would aid in dumping the energy at the end. There's a Bose patent which kinda shows it.
I'm not a good enough craftsperson to make a cut - I think it would be like below but add the flat plane then cut the aperture
a tube larger than the compression driver's exit will probably be rough. A conical adapter section would help.
lol, I just discovered Bose's patent this afternoon.
If anyone wants to check it out, here it is:
https://www.google.ch/patents/US8351630
Here's a pic of the device in action. See that compression driver at the top of the TV?
