eq'ing horns
Was just searching for prices on the lab12 drivers when I found this post by Tom Danley.
http://www.audioroundtable.com/HighEfficiencySpeakers/messages/569.html
About halfway through he gives some thoughts on eqing the roll off of horns.
Rob.
Rob.
Re: eq'ing horns
True. You can EQ anything to varying degrees,it just depends how much you understand what is happening,and what your requirements demand.
Personally I wouldnt since generally the subwoofers are the most demanding.
He doesnt mention excursion,only power. Hornresp clearly shows the excursion below Fc,which is probably similar to a sealed box.
RobWells said:Was just searching for prices on the lab12 drivers when I found this post by Tom Danley.
Rob.
