Which Alpair drivers, if any, need a BSC filter?
dave
Reactions: LeifB60
Still a work in progress:
dave
This is basically a series filter (instead of parallel which is more conventional).
Which is not always advisable because of the non-linear behavior of Le(X) as well as power compression (change in Re).
Although in this case it's probably fine 😀
One could do with a speaker less in a parallel filter design for BSC
I have been simulating this in Boxsim (just because it was quickest for me) and although the idea seems nice, it doesn't quite work so well unfortunately.
This is mostly because of how the attenuation works across all loads and therefor you don't get the +6dB you need at the lower frequencies. There is also quite some weird interaction happening in the impedance plot itself.
Also cost wise it doesn't make sense when the Le of the woofers is already very low.
This means a big capacitor. A simple inductor would be far more cost effective.
So I would just stick to the parallel circuit instead.
Yes, big cap, it says that in the picture.
These 2 solutions have completely different aims. Use an inductor and all of a sudden you have 6dB too much room response. Not the case for the series connection.
But usually neither is the goal, 2-3 dB of LF gain more useful.
dave
