Where to get schematic for old sansui amp?
I have this same model of amplifier and I like it a lot. I have replaced its output transistors with MJ21193 and 21194 since they originally blew up.
I want to know what the three pots are for on each amp board. I know that the one closest to the test pins is the bias pot, so that's fine, but I want to know what the other two are.
And does anyone know what the Q current is supposed to be for this amp? Or the usual voltage across the test pins? Either number will allow me to adjust the bias to spec.
Thanks.
