This is a question that was in my head for some long time.
If you look into this page (more or less in the middle), you can see the use of a solder tag strip for a crossover: CA18RNX
I can buy such a strip, but apart the obscene price for this simple item, I don't find it very useful because it is not easy to connect more that 2 wires together (look again at photo of the finished crossover).
I was thinking that something like this quick drawing could be more useful:
Basically the base is non conductive, all the tags are connected together, but it is easy to remove one or more, so you'll have some series of tags connected: if you need for example to connect 3 wires together, and then also 4 other wires together, just use the first 3 tags, then remove the 4th, and use tag number 5 to 8 for the other connection.
Do such a strip exist? It could be very helpful for building a crossover.
Ralf
Ralf
You can buy a dual in line (DIL) version of that first example.
It is most regularly used in Valve/Tube gear where they like to hardwire.
Cut it down the middle for single in line (SIL)
the big electronic parts sellers should have lug-type terminal strips (in german: lötleiste ).........and probably tube parts sellers too....
I think you all mean this: Tube-Town Online-Store - Lötleiste 2*10 Kontakte / 38 lo02-10
I've seen those strips, I think they are useful when you have to connect 2 (but no more) wires together. My question is still not answered: on a crossover is not too unusual to connect together 3 or more wires (I have an example of 5! I did it but was a PITA).
Ralf
Ralf
Would something like this do you?
Cinch 8 Lugs, 2 Ground Terminal Strip | 29F591 | Cinch
I use them all the time and they are cheap.
The advantage of the Cinch design is that they will hold off 450 V on adjacent terminals. Like a radial lead capacitor +, then two grounds together, then a plus of another capacitor, etc. I use the cinch design to replace $40 each 4 gang can caps with 4 each $3 radial lead caps, rated at up to 10000 hours service life instead of no life rating on the can caps.
Tubesandmore.com triodeelectronics.com and electronicsurplus.com have the cinch design, too.
Yes, plain old terminal strips like Pano's. Each terminal certainly holds more than 2 wires. They come in various lengths and numbers of terminals
- Design & Build
- Parts
- Where to find those solder tag strips?
