Where to find those solder tag strips?
This is a question that was in my head for some long time.
If you look into this page (more or less in the middle), you can see the use of a solder tag strip for a crossover: CA18RNX
I can buy such a strip, but apart the obscene price for this simple item, I don't find it very useful because it is not easy to connect more that 2 wires together (look again at photo of the finished crossover).
I was thinking that something like this quick drawing could be more useful:
attachment.php
Basically the base is non conductive, all the tags are connected together, but it is easy to remove one or more, so you'll have some series of tags connected: if you need for example to connect 3 wires together, and then also 4 other wires together, just use the first 3 tags, then remove the 4th, and use tag number 5 to 8 for the other connection.
Do such a strip exist? It could be very helpful for building a crossover.
Ralf
The advantage of the Cinch design is that they will hold off 450 V on adjacent terminals. Like a radial lead capacitor +, then two grounds together, then a plus of another capacitor, etc. I use the cinch design to replace $40 each 4 gang can caps with 4 each $3 radial lead caps, rated at up to 10000 hours service life instead of no life rating on the can caps.
Tubesandmore.com triodeelectronics.com and electronicsurplus.com have the cinch design, too.
