When to use baffle step compensation?
Tom, the LDC is right. I've got you had microphone 1/4" in front of the cone. Thus I think that I've written the BS did't affect measurements. Sorry for messy czenglish 🙂
The small enclosures seem to suffer the most from BS.
I think so. Specially 2way where BS always falls into midwoofer's region.
Tomáš
soongsc said:
bi-amping is a little tricky. First you need to compensate for impedance variation, then listen and measure to determine if BSC is needed. If BSC is needed, you will most likely have to implement it prior to bi-amp.
How do one apply BSC prior to bi-amp? Do you mean apply BSC between preamp and active crossover for all 3 inputs of low, med and high?
Well, I consider active crossover part of the bi-amp (or tri-amp) just becasue that where the signal splits. So we're talking about the same thing.
yep, I built 2 sets of speakers using identical drivers, one pair are 50cm wide and skinny, to go against the wall, and need no BSC; the other pair are made from 30cm pipe , baffle width 21 cm, and they defintely need BSC, even though they're hard against the wall.
Currently I'm using Rod Elliot's line level BSC, but probably will eventually put in a big inductor
One thing to keep in mind when using BSC is that at the same volume level setting, you will have less output. So in order to obtain the same listening levels, it's probably good to check if you have sufficient Xmax to support the same listening level you are used to.
planet10 said:
Pretty much eliminate...
dave
Cool, that means I'm learning 🙂
I now wonder why do most the designs I've seen, in particular the fostex bass reflex recomended enclosures, are made narrow and deep?
Being able to go crossover-less / filter-less is one of the main advantages of fullrange I thought.
