Is the Pensil an MLTL or a TABAQ?
The TABAQ is a MLTL design. The Pensil is a MLTL variant also.
My first build was a TQWT (Tapperd quarter wave tube)and still lives with me today... I used a Philips AD9710 no filter and industrial carpet to cover the inside. Although I have build some other speakers this first build still sounds great and will never leave the house.
The total costs including the drivers was around the €165...
I'm looking to build my first full range speaker.
What's the easiest build for a beginner?
Welcome to the Forum, also being a newbie on here i can say with experience the forum members here are a brilliant at helping you achieve your diyaudio goals!
I am currently going through a similar experience on what to build (actually looking to build a few enclosures).
What Driver/Loudspeaker will you be using? I'm using the Mark Audio Alpair 7.3
Does you £250 budget include the speakers or is that just for the build of the enclosures?
Thought i'd share some ideas with you as you said you liked the pensil series
Woden Design
You may like the look of these.
Meet the Fonkens
A little warning, like you i was going to build a simple bass reflex box, but after communicating with the guys (i blame chrisb) i am now planning on building a set of trapezoid mini onken enlcosures, and to help in low end bass department i want a FAST system of some form. Yea i didn't know what any of that meant last month either hahaha.
You should if possible go listen to a few of the designed enclosures, if thats not possible the simplest easiest build would be a simple bass reflex design (again repeating the advice i've been told) With a Good Full range speaker, a good amp it will make you enjoy your music until you get bored and want to try another more challenging speaker design (maybe thats just me?)
Good Luck and enjoy
Good Luck and enjoy.
That's the spirit!
Edit: I think more of us can put some form of "blame" on Chrisb for his advise and encouragement. And of course Dave (P10). Hearty thanks to both!
IIRC, I spoke from the outset on the extra challenge of the trapezoid shaped enclosures, particularly for something like a floor standing tower for "sub" woofer support of the smaller FR drivers, so vish needs to own up to some of that .
and re the Pensils, to avoid putting words in Scott's mouth -something for which he has low tolerance - I'll quote from the front page of the full plan set (circa June 2011)
http://frugal-phile.com/boxlib/pensils/Pensil-Series-set-100711.pdf
"Damped Air Coupler
They use a combination of traditional quarter-wave design, a custom T/S volume alignment, and Transmission Line damping to provide a balanced response with a flavour of both vented and TL enclosures.
The Pensils are designed not to require any form of correction circuits for (baffle) step loss. This is achieved through a combination of the compensation already built into the driver responses, and the damped air alignment, which together bring the system response ~ flat in room. The impedance load is easy, being largely unreactive, and driver displacement is well controlled"
Note that with several new / revised drivers since then, this particular plan set might be not fully up to date.
"Damped Air Coupler
That's the spirit!
I was being cheeky i wouldn't have it any other way zman, and you said it best "advice and encouragement" that's this forum all the way with members like you guys on here.
Example above, "Tabaq" is a well discussed enclosure on the forum. It has its own mammoth topic and has spawned a few discussions elsewhere. One thing it doesn't do is to be particularly loud.... If built using a single 3" driver.... There are, however, variants using 4", 5" drivers and even more traditional 2-way systems.
Three "contemporary" designs come to mind (in no particular order):
Pensil 10.3
Bob Brines M10-A10 (paid plan set)
Big TABAQ for Alpair 10.3
Jim Griffin MLTL for Alpair 10.3
Oops - that was four!
Pensil 10.3
Great stuff. I'll get searching unless you have links for each of these .....
Links:
http://frugal-phile.com/boxlib/pensils/Pensil103-plan-300114.pdf
M10-A10
Large TABAQ plans here: http://www.diyaudio.com/forums/full-range/88787-tabaq-tl-tang-band-87.html#post4016103
Important modifications for for Large TABAQ for using with Alpair 10.3 discussed here:
http://www.diyaudio.com/forums/full-range/88787-tabaq-tl-tang-band-89.html#post4043489
http://www.diyaudio.com/forums/full-range/265066-mark-audio-alpair-10-3-mltl.html
M10-A10
Four "contemporary" designs for the 10.3:
Pensil 10.3 - http://frugal-phile.com/boxlib/pensils/Pensil103-plan-300114.pdf
Big TABAQ for Alpair 10.3 - http://www.diyaudio.com/forums/full-range/88787-tabaq-tl-tang-band-10.html#post3292265 with adjustment for the 10.3 http://www.diyaudio.com/forums/full-range/88787-tabaq-tl-tang-band-18.html#post4043489
Jim Griffin MLTL for Alpair 10.3 - http://www.diyaudio.com/forums/full-range/265066-mark-audio-alpair-10-3-mltl.html
I'll be honest, I'm struggling to see the differences in these designs! It's it just a box with a hole in it?
You beat me to it! Thanks
Just... looks like our posts crossed.
- Full Range
- What's the easiest build for a newbie?
