What size Lcd do I use for Best results?
I want to build my own Projector and have been readind about what size to use. I can get a 7" wide screen lcd for $119.00 would this be good or should I get a bigger screen like 15 - 17". If so how do I use the bigger screen? Do I need an Over Head Proj.?
Any suggestions would be greatly appreciated.
There are several options for using a screen. I have built two projectors. One uses a projection panel I got off ebay and I have had great results with. I have also used a desk top monitor and the quality is very good. It is just a choice of size vs. quality. If you use the smaller screen you will have less quality, but a smaller projector. It is basically your choice.
If you had a link to the 7" screens that we might be able to tell you more about their quality.
