What Pass Labs amp is this?
I am NOT a DIYer so it may be a stupid question. The seller doesn’t know what amp this but he says it is supposed to be a Pass Labs circuit. He bought it from someone.
Can you tell what model it is? And how well/cleaned it is made? Looks neat to me.
This is also what he mentions about the specs but I don’t know how accurate it is.
Very nice sounding 30wpc class Internal working voltage: two groups of independent double 35V DC
Pure Class A output power:
26W*2 8 ohm speaker
30W*2 4 ohm speaker
SNR: 108db
Looks like each channel has three electrolytic capacitors, three TO-220 transistors, and a TO-92 transistor, so that definitely suggests an Aleph circuit. Only two TO-247 devices per channel, so it must be essentially an Aleph-mini with higher rails and bias.
Yes, A30 would likely be interpreted as Aleph 30 in this context. But, there are some key differences between this amp and a true Aleph 30. For one, the Aleph 30 had more output pairs (6 pairs in total, if I remember correctly) instead of a single pair per channel. Also, an Aleph 30 would power double into 4-ohms. The lack of additional power into 4-ohms for this amp could be caused by lower overall bias (being limited by the single output pair) or a different current gain setting (or both).
This isn't too say it's a bad amplifier, just not really a true Aleph 30.
Reactions: jencelo
