I like my own bicycle best.
Also worth noting that during the past 50 years we did nothing but replace IBM 3270 terminals
with HTML terminals.Welcome to the cloud yay!
Somebody finally noticed that.
Personally I'm more into Dutch Amp
Guys you left me totally confused with these things opamps. I asked Deepak Chopra about them and here's what he had to say:
"The good opamps project onto silence, illuminating only essential space time events."
The concept is different. Because we have lots of limitation with handheld devices (such as memory size). Conceptually, any programming is similar, but the point is you cannot develop an android application only by reading/knowing Java and Linux. You have to read/learn another extra knowledge (even a new Integrated Development Environment; imagine if Google Inc. made Eclipse or old IDE unusable)
Please try to program microcontroller that have 2KB flash memory and 1KB or less RAM 😀
It only need to learn algorithm. Although I don't remember all C syntax, I still can made program for smartcard (contact and contactless) reader using LPC1788.
I programmed a Kim-1 by hand-writing assembly and entering the hex code about 40 years ago. The wonder now is why Kim-1's are priced so high for such a small amount of RAM (and no FLASH or even EPROM).
Yes, I work with micro-controller too. The thing with android application is not just limited processing power. Too many that I don't need to mention. And it is not fair to compare handheld device with micro-controller. Handheld device is supposed to replace PC, not just displaying "Hello world!".
How long before someone points out they can still remember the toggle sequence to bootstrap a PDP-8!
Oh S**t! Did that push a button!
Welcome to senior housing community...
It is same. I learned how to make program on android too. Just for fun. I made bluetooth communication, etc. using eclipse.
points
Back when, I forgot my keys so many times that I rewrote expired magnetic debit cards.
Thought I'd call it quits after trying to draw cash from an ATM with the gate opener.
Guilty... Started programming in assembler on pdp8s... Punched cards - then at last! a teletype with paper tape for local backup linked via a 300bps acoustic coupler to a pdp10!! Heaven! The pdp10 had drum storage, the drum was huge, in it's own airconditioned room....
. . . and now we can buy a $20 or GBP20 (the currencies are just about worth the same I hear) mbed module that fits in your hand that's more powerful. 256k RAM, 2MB FLASH, USB, A-D etc etc. Ditto all sorts of other modules as well.
I used to love pointing out that the first generation SIM cards basically had a commodore PET inside. And even today you are never far from an 8051!
- General Interest
- Everything Else
- What is wrong with op-amps?
