What is wrong with op-amps?
No, purely advertising.
Did you actually pull any and test them? Two recent gadgets had fake advertising features and no one seems to care. Both a solar powered calculator and one of those shake to recharge flashlights had coin cells hidden in them. The solar cell was a piece of plastic and the "generator' in the flashlight had a slug of metal instead of a neo magnet. Late 50's and early 60's transistors were not particularly cheap, I have a hard time believing the unused ones were 100% to spec, the yield to noise for instance was abysmal.
Yes the sharp folks tested and graded all their transistors to use them where best. So the dummies probably were the worst if even functional.
In my youth a VTVM was about my limit of test equipment. So testing transistors for other than diode action wasn't on my list of capabilities.
I have seen "three way" loudspeakers where there were no wires to the "tweeter" wires to the midrange terminal strip but no voice coil. Not surprisingly there was no crossover.
So what do you expect from folks who stuff in unused parts to increas advettising claims?
I have a 7 Transistor radio.
Here are two zero-transistor radios from the hands of a promising diyer youngster (there is still hope 🙂)
George
The original post was "what is wrong with OP-amps?". In 2016 (and probably in 1997~2016) the answer is "nothing".
Selected and designed carefully = piece of wire with gain.
If you want tube effects, buy tubes. If you want no effect, buy OP-amps. If you want touchy-feely vinyl, buy vinyl. But use OP-amps in the pre-amp 🙂
With small gain. The more, the worse. 🙂
Sometimes it is better to use a couple of opamp stages with low gain than one stage with high gain.
Or a composite, which get exponentially easier to stabilize at higher gain. Then again, outside of mics and phono preamps, when do we deal with high gain in audio? Even the multi-KW power amps of the world are around a G = 50.
From an entirely simplistic point of view, guess that is a reasonable point of view.
Please define "selected"?
And also "designed carefully"? Is that the opamp or the circuit?
I need to know, so that I and others reading along know what and how to do it.
_-_-bear
