So, what I'm trying to understand, or work out, is, that given the argument that many buyers will have different rooms, and these different rooms will affect a given speaker in different ways.
Is there any one area of speaker design that will help the speaker present a decent account of itself ?
I'm trying to understand the mechanics and ideals better as I'm slowly learning the basics myself.
And there's been a flurry on diy about such deeper topics.
It's all hogwash as far as I'm concerned but then again I'm old school - 70's 🙂 and yes, I believe the room and it's dimensions affect speaker sound quality too.
One area? Yes, simplicity. This could be subdivided into other areas, is that ok?Is there any one area of speaker design that will help the speaker present a decent account of itself ?
Minimum number of drivers and hence xover points. Time-alignment 😱. Sealed box. Baffle Step Correction. I wonder why no manufacturers have thought of these things before 😕🙂
Actually, that's where DIY can have an advantage, choose and build the speakers that work with your room, as a system.
I don't particularly like this simplified explanation as all it does is confuse people even more.
Particularly this one:
Even designers like Troels make sure they have a time aligned design, even though he likes to use second order filters. Yet this is different from what Dunlavy tried to accomplish with his first order filters.
This difference between the two is easily seen in the STEP response of the speakers. Aside from the audible differences between these topologies, I don't think it's wise to say it's all the same.
Grimm Audio is an example of speakers that use DSP FIR filters to get similar results to Dunlavy, the FIR filters make up for their use of higher order filters. Here is a whitepaper of their LS1 speaker.
Just calling it all the same thing just does not work out that well.
We have enough problems as is with people that are convinced they use first order or second order filters without realising it's the actual acoustic slopes that count. How many just slap on a LR2, either in passive form, obtained from an online calculator or active where they just pick out the slope as a pré-set and think they are done.
I don't think we can dumb down the discussion without creating even bigger confusion.
Yes, I understand your point. I deliberately dumbed it down hoping that people would then follow my explanation further.
Let us not forget that many here are not experts in this field. Time aligning the woofer and the tweeter is confusing enough. Bringing FIR filters into this will make it worse. My intention is to help explain what is the meaning of Time-aligning the tweeter and the woofer in the traditional sense.
If I had said this from the beginning, Phase alignment is not Time alignment and aligning acoustic center of drivers doesn't mean the two drivers are time aligned, it will create even more confusion. That contradict what I said right at the beginning about phase alignment but it's true. So, bear with me, one step at a time.
Only one person has got the answer right so far. Time alignment is done by making sure the voice coils are aligned, usually done by angling the speaker baffle. Bang and Olufsen studied this in the 70's and it has nothing to do with phase alignment of the signal which is usually when the one speakers wires are connected the wrong way round.
Nope. Time alignment is about the arrival time of the tweeter and the woofer. If they coincide exactly, the two drivers are time-aligned.
Whether the voice coils are aligned, tilting baffle using step are all methods. If you use a step and yet sounds from the tweeter and woofer don't reach you at the same time, the drivers are not time aligned.
This thread appears to be specifically about the crossover region, so there is a lot to be said for keeping it as narrow as possible.
No, it's about time-aligning the woofer and tweeter. It means sounds from the woofer and tweeter reach you at the same time. If they do, the phase of the two drivers at the crossover frequency will be in-phase.
A text from Bob MacCarthy I found to be quite informative about time and phase alignement: Time & Phase Alignment - ProSoundWeb
I find the wikipedia article linked to clear and concise
I believe you are refering to this:
"Loudspeaker time-alignment usually simply referred to as "time-alignment or Time-Align" is a term applied to loudspeaker systems which use multiple drivers (like woofer, mid-range and tweeter) to cover the entire audio range. It is the technique of delaying the sound emanating from one or more drivers (greater than 2-way) to correct the transient response, improve accuracy and, in non-coaxial drivers, improve the directivity or lobe tilting at the crossover frequencies."
In a broad sense, yes. My thread is specifically about time alignment of woofer and tweeter in a 2-way speaker. When are they deemed time aligned and later how to do it so that everyone here can try it for themselves.
There seems to be some confusion as to what Time-Alignment is.
Simply put, it is the aligning of the woofer and tweeter acoustic phases at the crossover frequency.
Time alignment refers to aligning the acoustic phases at the crossover frequency.
Phase alignment is Time alignment. When you align the acoustic centers, the phase of the two drivers at the crossover frequency crosses perfectly.
You are over thinking it. I keep on saying it is at the crossover frequency.
I do apologise, for some reason I thought you were referring to what can occur at the crossover frequencyNo, it's about time-aligning the woofer and tweeter. It means sounds from the woofer and tweeter reach you at the same time. If they do, the phase of the two drivers at the crossover frequency will be in-phase.
This thread can benefit from some virtually "perfect" examples in graph form.
Simply showing what happens with a certain crossover topology and how it sums together. As different order crossover slopes do change this game even more. Making it even more complicated to follow for a lot of people.
Yes, pictures are good. It's ironic that the use of words can easily make simple things complicated........easily 😕This thread can benefit from some virtually "perfect" examples in graph form.
No, no, please don't apologize. I just want to help members understand what is the meaning of time-alignment in a 2-way speaker.
Actually, what I said earlier is inflammatory to experts. They are completely wrong, especially the part that says Phase alignment is Time alignment. It is NOT. It is the other way round. When the woofer and tweeter are time-aligned, the phase at the crossover frequency is aligned.
Haha, please God, save us from "experts" 😉Actually, what I said earlier is inflammatory to experts.
Yes, I'll come to that later. Have to drive my wife now to the doctor for her annual checkup. It's no fun going out in this temperature. it was -10F yesterday.
This is not correct. Correct time alignment does not mean phase alignment has also occurred. Any phase relationship between drivers can exist when time aligned.....for instance, time align and then swap polarity of one driver...still time aligned.
FWIW, here's my simplified take on time alignment, phase alignment, and to risk some more advanced discussion...linear phase alignment.
First comes time alignment...as several have noted, it is simply having sound from different acoustic centers reach a designated listening/measuring point at the same time. Can be done via geometric driver positioning or pure time delay(s). It's just a little exercise in triangulation to a particular point.
That achieved, next comes phase alignment. It is having the phase traces of overlapping drivers lay on top of each other through the region of acoustic summation. The traces don't have to be flat, they just have to have the same slope/shape and lay on top of each other. This is accomplished by considerable experience with crossover design, and measuring expertise.
Phase alignment does not mean all frequencies arrive at the listening position in phase. It means that on a frequency-by-frequency basis, any particular frequency coming from two drivers arrive in phase.
IOW, phase alignment does not mean 100Hz necessarily arrives in phase with 10kHz.
If it did, that would denote the last step, linear phase. This is where all frequencies arrive together in phase. (and of course in time too, first step)
It's accomplished with linear phase crossovers and the phase correction of drivers' natural acoustic roll-off, using FIR.
If all this has made sense, let me pose a question that finally led me to see 'what I believe is the light behind all this....'
What does it mean for all frequencies to arrive in time and in phase together?
What part of the waveform are we talking about arriving together?
Hope this helps 🙂
Also the tweeter cone/dome will probably move much faster and will decay faster than the "slow and heavy" woofer cone.
Hope this helps 🙂
Mark, thanks for your input. I understand what you're saying but I think it's better to leave out linear phase for the time being. That's more advanced than aligning the tweeter with the woofer.
That's what I mean by time alignment and phase alignment. When you flip one phase, you'll get cancellation. It doesn't mean they are time-aligned, just phase aligned. You still need to determine that the two sounds arrive at the mic at the same time.This is not correct. Correct time alignment does not mean phase alignment has also occurred. Any phase relationship between drivers can exist when time aligned.....for instance, time align and then swap polarity of one driver...still time aligned.
Bear with me for a while longer. I will show with measurements how I time align my woofer and the tweeter. 🙂
My next post is heresy to some. 😀
Aligning Acoustic Centers of drivers is NOT Time-Alignment
There is this believe that when you align the acoustic centers of the woofer and the tweeter, the speaker is then time-aligned.
So, one happily uses a step, tilt the baffle, dial in the delay electronically or whatever to align the acoustic centers and there you have it, a time-aligned speaker. The speaker is NOT time-aligned.
Why?
To find the acoustic centers, you measure the time difference between the drivers arriving at the mic. So far, so good. But you do this with the source directly connected to the drivers.
When you install your crossovers, there will be phase shifts. So, to determine the true arrival of sounds from the tweeter and the woofer, measurements must be taken with the crossovers installed. In other words, you need to take one of the tweeter with the high pass network, then the woofer with the low pass network. If the two signals arrive at the mic exactly, then they are time aligned.
Sorry, I have to leave for a while. I'll be back after lunch with graphs to show what I mean.
Why?
- What is Time-Alignment
